UKs 78 SN |
Post Reply | Page <1 678 |
Kristof
I don't know if your phone works with the "+", but if it does, that's the complete number to reach me from anywhere. (Country code for Belgium is either 0032 or +32) |
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1412 |
Kris will be great to meet up just give me a few months to finish off some other parts I have on the go, and it will give me a push to finish off the house rebuild, have already thought of my CCF friends around the world and now have a built in coffee machine to fit so all you need to bring is the beans you like and show me how to work it.
I'm working on a bank job at the moment so time is tight (yes I know you like driving but I'm ok for a driver as its not that type of job) but sure we meet soon a share a few beer's or ales. I take it the number you post just need the country code added first. Greg just lean up the mixture and the chevy power should do the 4k on a tank. |
Lets have a go
BuffaloBFN
If I could get Pete to tell me how to change my raw water pump to a sea water pump, I could get there in 5.5...
Too bad my concord is in the shop. |
Kristof
Yes you did Greg, but it's just a little more than 6 hours from my home...
BuffaloBFN
Didn't I ask first? |
Kristof
Just talked to my Chief... No problem in getting two days off to come see this little marvel (showed him the pics ).
Wouldn't be a problem to come look at it. Got anything to do thursday evening...? Give me a call: +32476/259.477 |
uk1979
Thanks Kris but my stuff is small beer to you,as all who serve for us to be free gets my vote.
Seb I'm sure we will meet soon and keep your post coming great stuff. Here are some more pictures. |
Lets have a go
kapla
that thing looks wicked!!! to bad we are crossing by..I´d really would have love to see your work personally!!!
Kristof
Roger, that's just plain marvelous!!!
I think I'll have to make a quick trip to the UK soon to see that art work in person... Don't just cover her up yet... You can teach me a thing or two. I can even take two days off at work and come by after you finished work and drive back the next morning... (Can you tell I really really wanna see this craftmanship up close?? LOL). Shoot me a mail: kristof.erens@skynet.be |
uk1979
Can not load more pictures will try later, should be filling up this week who can guess the weight of them 2200mm long.
Lets have a go
uk1979
Hi Guys well had a go at making ballast tanks for each side here is how I did it.
Lets have a go
uk1979
Used some pipe foam and it did work out.
Used an off cut of armored cable inside which helps hold in shape and if you twist the foam it makes a bend then tape. As for pulling out fixed a washer to the end of cable and held in vice to pull out. |
Lets have a go
uk1979
Hi Guys thanks for your kind words but none of you warned me about getting hooked on playing with Epoxy & Glass, here are some shots on how I made it.
Have looked around over here as Pete said for Epoxy supplies the West System is good but when you have a Epoxy habit the cost is to high found this one which has many types for different applications even one to make fuel tanks and a Epoxy foam for structural work, the cost is now 50% less now I buy it in a 43Kg drum kit. Sicomin Epoxy For tubes used Foam edge protectors we use on tops with wood inside if you need a bend just put bits in and then just staple plastic pallet banding along the sides loop round one end and staple down the other side leaving long tail at on end,so when dry you can rap around a stick and pull out. When you fit the foam together over the wood you can make the bend and hold by the odd strip of masking tape then wrap the hole thing in Cling Film /Pallet wrap. As for matting I used 4 axel cloth just in 2 strips each side well wet it will give and shape if you work it around the bend and wrap again with Pallet wrap tight,when all wrapped up you can smooth out a crease with you hands. Make it longer than you need and cut to size,then set up in the boat on blocks and glass a web across to hold together when dry take out and build off it for main ducked,I went for 6inch flex as we have that here. When I had the basic shape right then cut the hole out on the main clean up and add more layers to ouside around joint and 6inch pipe. Thinking about the foam I think you could use the type used on pipes will be trying that out. Thanks again guys Roger. Please be careful with this info you may get hooked think I have it bad |
Lets have a go
That is so cool. Wish you werent in the UK... Id ask you to make me some!
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5773 |
Did you built the tubes? what did you use for a core?
Roger,
I sure like the idea of using the resin/glass. No problems with it bonding off at bulkheads like you may have with PVC or other tubing. Just more work!! You sure are the pro with the vacuum bagging!! |
BuffaloBFN
That looks well thought out. Would you tell us some of the details?
I gotta hang out in your shop someday!!! |
pretty sweet work there roger.. top drawer..
uk1979
Odds bits I made
Lets have a go
