Has anyone ever heard of this |
85Nautique
Groupie Joined: April-30-2007 Location: United States Status: Offline Points: 69 |
Posted: September-12-2007 at 7:44pm |
Hey guys I am looking for a intake adaptor to put on the intake hose for the raw water intake hose before the strainer so that I can attach the garden hose directly to the raw water intake hose so that I don’t have to use a fake-a-lake a buddy of mine used to have one on his boat not sure where he got it so I am ask you guys to see if you guys think it good or bad and to see if someone has done it in the 2001.
Does home depot have these parts to do that? |
bwill14
Groupie Joined: May-11-2006 Location: United States Status: Offline Points: 75 |
I am not sure about Home Depot, but SKIDIM does. Works pretty well from my experience. Here is a link to the product:
http://www.skidim.com/prodinfo.asp?number=DP6 |
Brent
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21136 |
Been there, done that. Yes, you can get the parts at HD for ~$15. You'll need a plastic 1"x1" T, an NPT-GHT adapter, and a plug. Instead of a plug, I use a valve.
I always just pulled the hose at the pick-up and and clamped it around the garden hose no leaks no fake a lake cheap. Tims set up works just as easy too.
LaurelLakeSkier
Senior Member Joined: February-12-2007 Location: Wisconsin Status: Offline Points: 485 |
I like your idea of using the valve.....looks like there may be a trip to the hardware store in my furture.
only bad think about your set up tim is you can get a lot of air in the flow of thinks, maybe you block off the other end but if not?
jbear
Tim; Looks sweet...like everything else under your motor box.
john |
not to be critical, but your trans needs some paint
jbear
You gotta be kidding...you seen the rest of his motor? Who looks at the tranny anyhow?
LOL....just kidding eric. john |
Barracuda
That's pretty crititcal We know you're just kiddin Eric. Even so, I'll bet you 5 bucks Tim is out there with a can of rustoleum this weekend. |
What's the hose with the cap that sticks up out of the bell housing?
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
Tim
That is a nice setup. But like 79 asked, do you have a problem with air in the water stream? My trailer bunk partially blocks my intake, so my fake-a-lake doesn't work. (anyone need one?) That setup will work great for my boat. I'll make a plate to block the intake when in use. Thanks, Lefty |
'85 BFN '90 BFN White Lake, Michigan |
3-way ball valves! No cap. Just a 3/4" garden hose adapter. Go oversize so the ball port is full size. |
No problems at all. Im sure the RWP is drawing some air through the intake grate when its on the hose, but theres plenty of water going through to keep the impeller lubricated. Since theres no load on the motor in neutral, it stays at a constant 160. I cant catch a break with you guys! The engine actually needs paint as bad as the tranny- the whole point of the shiny pipes was to distract your attention. Riley, the 12" terminated hose coming off the top of the transmission is the PCM-perscribed fix for the early 1.23:1 transmissions. M3Fan installed it to cure the buzzing at idle. Pete, that 3-way valve would be a monster considering youre hooking it up to 1" hose. By the time you add the barbs and GHT adapter, I dont think that would make for a very clean install. Besides, is there any real advantage to closing off the intake grate when youre on the hose? I run cool and get long life out of my impellers. If I forget to shut the valve when I drop it in the water, Ill suck some air and start to overheat at idle. With a shut off, you'll fry that impeller pretty quick with zero flow. |
quinner
If you do not have a setup like Timmy or a Flush Flo Pro IMHO the best way to run on the trailer is putting your intake hose and a garden hose in a 5gal bucket, when running directly from the garden hose if you rev the engine at all it will collapse the hose as the draw is greater than the flow. When running in the bucket you always have a reserve of water should any revving be necessary, this system also works well with getting anti freeze in the motor, after you drain all the water just fill the bucket with Anti Freeze and run.
Whenever running from the hose only I would be careful not to come off idle, the hose will not keep up with the draw. |
Ok guys!! I'm back to my fake fake-a-lake!
85Nautique
I am a little confused so is there a cheaper way of doing this? I thought this might be a 25 dollar part run to Lowes. Not a 57bucks order from SkiDim. Is there a down fall to doing this I was going to use this so I don’t have to use the fake-a-lake and so that I don’t have to crawl under the boat to run the hose. I was thinking this would be a easy way to do things. I am second guessing myself.
Do you really have to tape up the Intake opening on the bottom of the boat every time you want to use this. |
Did you read my post? The simple T and fittings to connect the garden hose will only cost $15 from Home Depot. No need to close the intake grate. This has worked well on all of my family's Nautiques for years. |
85Nautique
Thanks sorry I understand Now thank you!!!
I am reading this and answering phones at the same time |
69 Mustang
Senior Member Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
Can anyone post a pic of the 5 gal bucket set-up?
I'm leaning toward TRBenj's set up, but I want to do my due diligence. Mike |
For every complex problem, there is a solution that is simple, neat, and wrong.
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
JAG459
Groupie Joined: August-12-2005 Location: United States Status: Offline Points: 61 |
What the hell. Here's one more setup. Despite what everyone says, in the 13 years since I installed it I've never once failed to return the valve to the correct direction after flushing. Even though this setup works perfectly if I ever had to do it again I would install the Flush Flo Pro
bkhallpass
BKH |
Livin' the Dream
69 Mustang
Oh! I always thought those were the 18.927059 Liter buckets. Boy do I feel dumb...
So what do I do? Just wave it in the general direction of that hole in the bottom of the boat that makes me so nervous? Do I need to take all the drywall joint compound out first? Lid on or lid off? Does it have to be white? I see the orange ones with the little cartoon guy on them sometimes. Or is just owning one enough? If I borrow one, but don't own it, will it still work? Maybe I have this all wrong - should I just put in the boat and cover it for the winter and all will be fine? Screw it, just going sell the boat before it gets cold. The trailer tires have summer air in them anyway, I don't know where to get winter air. Seriously Brian, I had that coming - nice job! Now hand me the board stretcher, this one is too short. And I think I'm going to need a piece of shore line and a hurtz donut. Mike |
bkhallpass
It's all fun Mike. I wish I could help you, but where I live winterizing a boat means you throw in an extra sweatshirt, and little blanket for your passengers.
I would think you would sit the bucket in the bildge by the transmission. disconnect the intake hose and place it in the bucket, then put the garden hose into the bucket. As someone else suggested, the few times I have to flush a boat, or run it on the trailer, I just disconnect the intake hose, insert my garden hose, apply a hose clamp, turn the water on and go. You just have to be careful that the pressure doesn't compress the garden hose and cut off your water supply to the motor. The bucket prevents this problem. Some guys use the bucket to run anti-freeze through the motor for winterization. BKH |
Livin' the Dream
69 Mustang
BKH,
I hope you know I was kidding with everything I said. I kind of got on a roll and couldn't stop. I thought the image you posted was hilarious. Although now that I know you are one of those non-winterizing guys, well... Thanks for the description, I also use your method to flush. I just couldn't figure out how the bucket came into the equation. Thanks, Mike |
bkhallpass
Absolutely. Your response had me laughing so hard my wife came in the office to read your post. It's all fun. BKH |
Livin' the Dream
69 Mustang
Good stuff, Thanks BKH.
MaddMarxx
tullfooter
That was some funny sh** (especially, "should I take out the drywall compound?"). Started my morning, AT WORK ON A SATURDAY, off right, Thanks Lefty |
quinner
Mike,
As Brian described, the diffirence in using the bucket is you fill the bucket 1/2 or 3/4 full then start the boat, if you rev the engine at all you will see the water level drop because a hose usually can't keep up with the draw. Have a flush pro now so my bucket has retired. |
