Weak starter? |
Page 12> |
Author | |||
gt40KS ![]() Gold Member ![]() ![]() Joined: August-05-2017 Location: Wichita Kansas Status: Offline Points: 943 |
![]() ![]() ![]() ![]() ![]() Posted: September-03-2017 at 7:47pm |
Since the day I bought the boat, the starter seems abnormally slow, almost like the battery is very low. Both batteries always register 12.7 to 12.9 volts before starting and the engine starts just fine, every time. But it makes me a bit nervous because even with the dual battery setup I installed, I'm afraid the starter may give out while I'm in a remote area somewhere. Is it normal for the GT40's to crank so slowly or maybe the starter is old and weak? Or is it perhaps something else ....
Thanks for your input |
JCCI
1995 Ski Nautique GT40 |
Before buying a starter, check the voltage drops across the cables, also could be bad contacts in the solenoid. You could have corroded connections or cables.
If properly tuned a GT-40 with the proper fuel pressure starts on the first turn of the starter 9 out of 10 times. Shouldn't have to crank more than a revolution or 2 at most.
Well, she must be properly tuned then lol .... But still, I'm curious and concerned. It feels as though if it didn't start after that 1 or 1 1/2 revolutions that the battery wouldn't have the power to continue, which is the troubling part - plenty of juice. |
JCCI
Yeah, buying a starter was going to be a last ditch, especially since the engine has never failed to start in just one revolution. I have checked the contacts & cables and they are tight with no corrosion. |
JCCI
The info chris gave you is a good start.
I agree with Chris. He said "voltage drop"!!! So does Paul!!
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 10756 |
Well, if you want to find out if it'll keep cranking, why don't you pull your coil wire and turn the key? You'll see if the engine will crank for let's say 10 or 15 seconds with no problem or if in say 5 seconds the starter won't crank it over any more. Kinda a quick and dirty test to answer your curiosity and concern ![]() After that you can decide what you may or may not need to do. |
Ken's test could work two fold as in after a long crank I would bet that the suspect cable/wire/connection will be warmer than the other.
Of course a meter would be your best bet. |
Plus, you can determine if there's a voltage drop across the start relay (solenoid) due to bad contacts. Joseph, Why the dual batteries, what type of batteries are they and what type of combiner? Are you cranking on one or both? |
You can do a lot with a GOOD heavy gauge set of jumper cables too, like bypass all of the wiring to the starter
Since you have a 95, you should have the newer small starter with a starter mounted solenoid and also the remote solenoid/relay mounted to the back of the engine. Hook one cable from battery negative to the engine for a good ground and hook the other from the big terminal on the starter solenoid to battery positive. Then a short small jumper from the same big terminal touched to the starter mounted solenoid connection will let the engine crank while you're touching the wire. This could be a 12 gauge wire with an alligator clip on one or both ends about a foot or 18 inches long to give you a little extra to work with. The 2 connections are only a couple of inches apart on the starter. solenoid. See the picture, the jumper goes from the big nut on top to the spade connection in the picture. You might have the spade terminal or just a nut. Just a momentary touch to start the engine. No need to disconnect any of the normally installed wiring as long as you can make electrical contact with the spade terminal or the mounting nut for it. ![]() If the key is OFF it will only crank If the key is in RUN it will start and run even after you remove the small jumper and you then turn it off with the key. This bypasses all of the wiring to the starter including the heavy gauge cable from the battery to the remote solenoid, the remote solenoid to the starter, and the remote solenoid itself. If it cranks faster then you know you have a problem in one of those bypassed areas. If it's no better, then your starter or battery or in your case batteries, would be suspect if it cranks slower than you think it should. Notice that I emphasized GOOD heavy gauge battery cables and your starter should look like the one in the picture. If it's the older starter you can do the same test but a little differently. This is harder to try and explain than it is to actually do it ![]() |
Good info Ken. I might add that make sure you are in neutral because you have also bypassed the safety switch.
1978 Mustang (modified) |
Good thought there Duane ![]() |
Good info, I'll try the test next chance I get Ken. Thanks to all
JCCI
UPDATE:
I've done the test as Ken has described and the engine does in fact crank at the same speed as before. So apparently the cables and connections are just fine, as I had suspected. This does however bring up a more pointed inference of the original question that I had posed - Is the engine cranking more slowly than is normal for a GT40, or is the starter just weak? I suppose this is ultimately a subjective question relative to who is listening to the cranking speed and what they consider to be "slow". However, most of us at some point in our lives has had a very weak battery in their cars or boats to the point that the engine will just barely turn over. Continued cranking does nothing but drain the battery quickly to the point that it won't turn at all within a very few revolutions. THIS is the sense I get when cranking the boat. The difference is that when doing Ken's test, the cranking speed increased slightly after a revolution or two and stayed at that speed for a sustained amount of time. But again, just a small increase in speed. So, back to the dilemma: is this just the normal cranking speed of every GT40 out there, is it a weak starter, or is it just the normal speed of this particular starter? Who's to say, I guess. Suffice to say that at this point I now know it is not the wiring or the batteries and since she does start, first crank every time .... Thanks for everyone's input !! |
JCCI
I flooded out my starter last year with saltwater and just didn't feel like fooling around with it. Not being a weightlifter or 30 I bought the smaller gear reduction starter like you have. Check around and see if you can have yours gone through at an auto electric shop but keep in mind the price of a new one. I found this place had a good price on them-
Discount Marine Supplies |
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3337 |
one could disable the ignition and give it an extended crank.
Then quickly find the warmest component in the loop, from lugs, cables, connectors, solenoid, starter, battery post, not just POS but GND also. The warmest component, is then the most suspect component. |
Being one of those types that likes to have spare parts on hand, I'd buy another starter and put it in. Then you'll know if there's a difference and you'll have a spare starter too for the day when you need it..
A little voice in my head says you have a weak starter mostly because a GT-40 will turn over just as fast as any other 351 Like Gary said ARCO 70200 or something that cross references to it It's a clockwise rotating starter which is what you need for your normal rotation Ford. |
Gary, With myself getting up there in age like yourself and dealing with 80 lb. bags of concrete and 1/3 sq. bundles of shingles wearing the orange apron, I certainly understand the weight issue. However, you being one of CCfans best tinkerers, I'm surprised you didn't mess with the starter!! You know like I've said a few times, a good commutator and bushing cleanup is all it would probably have needed. I'm sure Ken would have tinkered! ![]() |
davidg ![]() Grand Poobah ![]() ![]() Joined: January-07-2008 Location: NW Chicagoland Status: Offline Points: 2239 |
I just picked up an '87 Martinique and noticed it had a very slow crank situation as well. I checked for corrosion on all connections, and wire brushed it all. Checked ground connection. Battery was very strong. Cables appear new, and VERY HD. I even took the starter to AutoZone, and they confirmed it was "good"....just because the drive gear engaged when hit with juice.
However, I still suspected the starter. Took it to a rebuild shop in the Chicago burbs that works on my stuff (and whom I trust), and my guy there called me today to let me know he rebuilt it. He said it was loaded with rust, brushes were busted up, and the drive was bad, He rebuilt it for $125. I will pick it up this evening and reinstall. I should be good to go. He told me to look no further as to the issue. We will see. I have been watching a lot of Youtube videos on this topic. An interesting fact emerged. ~90% of problems are usually cable or connection related. |
David, Now you know how good of a job they do with their "testing". ![]() |
What's a commutator? Is it a little economy car that you use to commutate back and forth to work Something like a Subaru Forester? What's it nickname? I forgot ![]() |
Ken, For the benefit of others who may not understand your "tongue in cheek" : "A commutator is a moving part of a rotary electrical switch in certain types of electric motors and electrical generators that periodically reverses the current direction between the rotor and the external circuit. It consists of a cylinder composed of multiple metal contact segments on the rotating armature of the machine." ![]() ![]() ![]() |
Well I didn't want to do it halfway,I would have had to take it apart,then I would have wanted to paint it. Then the fact it sits so low in that boat,the engine beds sit about 6" down from the top of the stringers, that I just didn't feel like messing with it. Then added to that we were about to take our 180+ mile river trip,that in the scheme of things $125 give or take didn't want to take a chance. All that plus the peer pressure too,I'd rather take the flack for not fixing the old one,I like being the boat in front of the rope. ![]() |
TRBenj ![]() Grand Poobah ![]() ![]() Joined: June-29-2005 Location: NWCT Status: Offline Points: 21138 |
Its no wonder it's so hard to find someone who rebuilds starters around here, when you can get rebuilt units on eBay for $90.. I wonder if the internals are of decent quality... but with a 1yr warranty I can't imagine they're that bad.
I just put my rebuilt starter on. That was the issue. Cranks like a Mack truck. Now I have to run to AutoZone and pick up a new deep cycle marine battery that the sales clerk recommended for starting my 351 motor....and get my new Fram oil filter. ![]() |
Being a kindred spirit, this is exactly what my inner voice was telling me to do... The wife was hoping I was deaf to the inner voice ![]() |
JCCI
HA HA HA.... funny stuff ![]() ![]() |
JCCI
Dave if your going to the Cary one will you check and see if they have any Spitfire spark plugs and some Slick 50? I can't wait on a JC Whitney order.
Tim, read the bottom line. Makes it worth while to put one on the shelf. That even sweetens the deal more Specifications: Unit Type Starter Voltage 12 Rotation CCW Teeth 9 Starter Type DD Brief MARINE APPLICATIONS WITH FORD ENGINES B+ STUD Item Condition ![]() ![]() |
Page 12> |
