Steering wheel |
Author | |||
dip
Senior Member Joined: August-29-2009 Location: Eastern PA Status: Offline Points: 392 |
Posted: November-07-2014 at 12:16pm |
Thank you for the advice. I'll keep you posted on the progress.
Darren,
Once you loosen the wheel nut on the column, you may need a puller. The Sheller wheel hub is tapered. If you are lucky, your wheel will have threaded holes in the hub. If a puller is needed, be real careful to apply pressure around the entire hub. Do not use an arm type puller. Some fabrication may be needed to make a plate for the hub backside. |
dip
Yes and no. The entire assembly is out of the boat but the wheel is still attached. My damn day-job is getting in the way of fast progress.
Darren, Did you get your Sheller wheel off yet? |
dip
They are very excited. I haven't used their services much yet since I've been stripping varnish and paint but they are eager for the process of putting it back together. They tell anyone that listens that it will be their boat!
It looks like a much nicer than average wood project boat. How do your kids like it?
dip
My reasoning was that the original question was answered and the answer to my question may have been a simple yes, then it grew from there. Still sorry to distract from the OP's thread.
No, Bruce, I haven't created a diary entry or thread yet. I should create the diary entry. I've been doing a lot of research prior to starting the thread so I have a well founded base of information! I'll start one soon. |
Dip, Did you start a thread about that boat when you purchased it and put it in the diaries? If not, now would be a good time as it looks like a nice boat and I bet a lot of people would be interested in it.
I learn as much from thread jacks as I do from the OT! |
There is no ownership of threads on this forum - so you can't actually get thread jacked - you got the correct answer for free - a link to where you could find the right wheel and if you wanted you could sell your existing wheel here quickly for a decent price. If you want more than that good luck with your cc questions on iboats |
Robert,
The title is "steering wheel" and that's really the content of the thread so I'm confused as to your concern. Yes, I did mention the horn button but that's part of the removal of the Sheller helm wheel. Don't forget that you also went into trying to find out the manufacture date of your boat. Good luck on iboat but do visit us too. |
skyfuzz
Senior Member Joined: August-17-2004 Location: South Florida Status: Offline Points: 239 |
Because you apologized it's okay...but it never fails, every time I post a question about my boat and its issues and I seek assistance here, I get t-jacked. iboat forum is way better most of the time and most are polite and helpful without wisecracks. |
http://www.correctcraftfan.com/diaries/details.asp?ID=7613&sort=&pagenum=1
Yes, it would have been mounted to a deck frame. The same with the relay. |
dip
Well, you learn something new every day...I did not know that was the horn button and it turns out the horn must have been removed from the boat at some point, though I don't even see evidence of a previous horn mount. Would it have been located where the one in this photo is?
No horn?? You should have one along with a horn relay. Have you been under the deck? Both the relay and horn should be there. At the bottom of the column, there should be wire. That's the ground source for the relay from the button. Yes, the button will come out with the throttle tube. |
dip
Sorry for the thread jack by the way. It seemed like a good place for one stop googling with steering wheel removal questions.
dip
Thanks, Pete. When you say the horn button, I assume you are referring to the center button which has no actual horn function. Does this come out with the throttle or is taking this off a separate endeavor?
Yes, But first you need to remove the horn button and throttle. At the base of the steering column you will find the linkage arm for the throttle. Remove it and the inner tube along with the lever will slide out. The nut holding the wheel on is underneath. |
skyfuzz
Okay thanks, I'll contact CC directly. |
CCFan Keith? No... You'll need to call or email correct craft directly. I've also had Art look up a few hull numbers when he heads over to the factory.
Highly unlikely but Pete or Alan will confirm. I've only dealt with 3/4" taper rotary systems- the older fully mechanical steering systems may be a whole different animal.
skyfuzz
I was told by the former owner that it is a '69. I have requested a manufacture date for my boat. I think Keith can get me that info. I don't remember who I contacted last time when I wanted the info on my former Barracuda but I think it was Keith. The hull # is WC19316. |
dip
Is it a similar process for an older wheel with a throttle?
He has a '69... At least he thinks he does!
You have the turnpike cruiser wheel on your '67? I don't think I've seen one used past '68. |
What year wildcat are we talking? The wheel on my 67 is light years more badazz than that. |
link |
Like Pete and Donald said, a small screwdriver or awl works well to remove the small spring clip. Once the cap is removed, the nut is accessible, hopefully the hub comes off the taper easy. Be gentle with the chrome cap holder, it's fragile.
This is the correct wheel for a Wildcat. You could reuse the hub, cap holder and cap from your current wheel. http://pages.ebay.com/link/?nav=item.view&alt=web&id=281379396067 |
Orlando76
Actually the steering wheels were generic so other manufacturers shared the same wheel. (At least the rectangle slots were) This wheel was common to Stars and Stripes MC. Skyfuzz, what do you plan to do with old wheel? |
From the dictionary: "awl noun a small pointed tool"
74Wind
The early 70s wheels I've seen have all had rectangular slots
Did they have round holes in the sixties or is that not an original? |
1974 Southwind 18
1975 Century Mark II |
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3889 |
I use a pick or a very small screw driver. It will flex and pop out.
