Need help! 84 not starting. |
NAUTI84 ![]() Senior Member ![]() Joined: June-10-2004 Location: United States Status: Offline Points: 485 |
![]() ![]() ![]() ![]() ![]() Posted: July-25-2006 at 8:38pm |
Ok guys, finally unwrapped and cleaned-up the old 84.
(Unfourtunately, it wasn't uncovered or started at all last year. ![]() I put a fully charged battery back in & reconnected everything. Squirted some Marvel Mystery in cyls & went to tap key to spin engine but all I get is a "click" at the solenoid. On the meter I've got +12v's at the cable going into the noid, but nothing coming out on the other cable? Tried a screwdriver accross the cables - got some sparks but nothing else? Any suggestions on which way to go would be much appreciated! |
stang72 ![]() Platinum Member ![]() ![]() Joined: July-31-2004 Location: United States Status: Offline Points: 1608 |
Check the simple stuff...look at your connections...bat cables and terminals...cable at the starter as well...clean um and try again.
Starter may have a dead spot and may be hung up there...turn the crank by hand a tad, lighty tap the top of the starter with hammer and then try. |
Thanks Stang, I'll give it a try (Nothing looked that corroded though.).
I'll pull all cables, clean, and reconnect to see what happens. Make sure I got it right: Even w/ key off I should have 12v's to solonoid and screwdriver across should spin starter? Are ya thinking it's on the starter side if I do this and only get sparks? |
Stang 72 is straight on. More than once I have seen this happen from the battery connections not being tight enough. First thing I would do is rotate over by hand (w/breaker bar if need be) to assure myself it was not the worst case.
And "worst case" would be??
Making sure the engine is not seized...and there is no reason at this point to think it is!
Btw...how many cranking amps does the bat have? |
bmiller ![]() Senior Member ![]() ![]() Joined: June-05-2006 Location: United States Status: Offline Points: 234 |
So when you jumped out the solenoid nothing happened except sparks.Sounds like a good connection to me.Did the starter even try to hit when you jumped it out?If it did then your problem is the solenoid.How old is the battery?If your battery is real old it could have a dead cell in it.If its good then my bet is the solenoid.That is if the engine turns,when you had it out last.
Nautique2001 ![]() Grand Poobah ![]() ![]() Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Can you try using your car battery to see if your boat battery is completely toasted? Got to bring that beauty to life!
Sure...if it has the CCA to turn that engine....650CCA or higher is what you need.
I'll try some things tonight.
Clean all connections. Crank engine by hand (Pull plugs right?) Give the starter a little whack. Engine ran fine when it was winterized 2 years ago. Battery seemed ok w/ +12 volts on the meter at the solonoid. When I crossed w/ screwdriver, Starter didn't even try to move. Ignition just clicks soloniod. Keeping my fingers crossed! Thanks for the usual great suggestions from this site! |
Take the battery and get it load tested first.Just because you have 12 volts on the battery does not mean its good.Your putting the cart before the horse.All that other stuff your going to try does'nt mean nothing unless the battery is good!
No need to remove spark plugs....with it in neutral...just turn it(once around) the direction your prop is...most likely ...when looking from the stern..clockwise(if you have rt hand prop).
Can you turn this by hand or do I need a large socket on the bolt at bottom front of engine?
large socket on the bottom bolt with a breaker bar would be good, not likely to be able to turn it by hand
Turn it using a large socket....be sure turn the direction as mention ed above...clockwise (looking from the stern)if you have a rt hand prop.
This will get your marvel working for you and will be easier to crank...it may move the starter off a dead spot. If you lightly tap the top of the starter with a hammer...have someone turn the ign for you and tap a few times while attemping to start...that usually will move it off a dead spot. |
David F ![]() Platinum Member ![]() Joined: June-11-2004 Location: United States Status: Offline Points: 1770 |
Turning the engine by hand will do nothing to the starter...it is not engaged.
My thoughts are that the starter is bad from moisture. Pull the starter and have it rebuilt or open it up and clean it up. You can also test the starter motor by apply 12v directly to the motor while on the work bench. Be carefull and clamp it down first somehow. |
jimbo ![]() Senior Member ![]() Joined: September-07-2004 Location: United States Status: Offline Points: 473 |
1. Try turning by hand.
2. Have the battery load tested 3. Apply 12V across the starter while it's still connected to the engine using a charged battery and jumper cables. 4. Try pulling the plugs and cranking the engine. |
Didn't get a chance last night, but heading out now to see what happens.
Wish me luck! |
Welp, a little less sweat dripping off my brow.
I did get her to crank - So I'm not seized up! First cleaned all connections & it still just clicked. Then used a jump starter direct to starter and it cranked ![]() Reconnected starter cable, tried ignition and it cranked again. But, tried it again and it just clicked. Went back to the jump start to starter & it cranked. So now I've got the battery back out, cleaned the cables/posts & charging over night. Seems like I've either got a battery or a cable problem somewhere. What do ya think???? |
Very likely! And if so...it's a small issue!
And yes David is correct..the srater is not engaged...but, (this is what I once heard)that the starter can be in a state where there is partial engagement...sort of stuck maybe?...and cranking by hand bumps it back. Does that make sense??? |
Yes, make sense I think can happen, especially if the bendix is sticking or on the way out. But, the torque of the starter motor will still let the engine crank. The bendix will just not disengage once the power is released from the starter.
Sounds like the starter is fine and just need to clean up all the electrical cables/connections between the battery and starter. |
the battery is junk if you do not have 13.5v at the battery then it's not charged and that's why you get the clicking and it cranks with the jumper pack/cables. Make sure you don't have undersized cables or automotive cables 2 gauge cable is fine for short lengths (2'-3') but is way undersized for a 5' and longer runs. Might want to clean the points a little before you crank it too much.
Ok - I've cleaned everything, disconnected & reconnected everything (2 or 3) times.
Played with neutral switch & breaker reset wires. These all seem to work Ok. I think I've got narrowed down to solinoid. Jumper to Right post (Pos.) just clicks. Jumper to Left post (Neg.) cranks starter. Off to SkiDim's website! |
tommer12 ![]() Senior Member ![]() ![]() Joined: February-05-2004 Location: United States Status: Offline Points: 366 |
You can get a new Solinoid at Napa for cheap and quick. Also, on Solinoids, you can usually whack it with a hammer to losen it up. Sometimes it is just stuck. But if you can connect the points to turn it over, then the noid is dead...
YEEEEE HAAAAA - IT CRANKS!!!
Finally installed the new starter solenoid today and key spun the engine ![]() (A trip to Nashville to buy a new motorhome & driving it back 1130 miles in 3 days delayed gettin this installed!) Well, now it's looking a little late to get any worthwhile use out of it this year. Plus I need to Register both Boat & Trailer. And probably need new trailer tires.(2 seasons without getting wet ![]() So I'm thinking that I'll just add some more Marvel Mystery to Cyl's and let her sleep another winter. Next year she'll be woken up real early! I'm happy that the solenoid did the trick though. |
nuttyskier2002 ![]() Gold Member ![]() Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Hey 79, I have to ask - what type battery is that you have that reads 13.5 volts while not charging. In my automotive electrical cla$$ at Florida Junior College we were taught that a fully charged battery would read 12.6 volts. Any higher voltage read than this, the battery was said to have a "surface charge". Now I've read some batteries recently that were in good working order that read 12.7 to 12.8 after their surface charge was dissipated. But none that read as high as 13.5. Are you reading this just after charging or are you letting the battery sit overnight prior to reading. Please let me know. Thanks!
JEFF KOSTIS ![]() Gold Member ![]() Joined: April-19-2005 Location: United States Status: Offline Points: 817 |
Me too!! Thanks!!! Jeff.... |
