Stalls when shifting into FWD |
Page <123> |
cool hand ![]() Newbie ![]() Joined: July-06-2010 Location: Brownsburg, IN Status: Offline Points: 17 |
Ok, so big thumbs down for N3 at this point.
So I authorized them to put a new carb on it if thats what they thought they needed to do. They're the experts, or so I thought. Call them at 430 (because they close at 5 and had heard nothing) and they say they're out water testing it, come on over it'll be ready when you get here. So I get there, talk to the tech, he says he couldn't get it to run at all with a brand new carb, so he cleaned up the old one and put it back on and took it out and tweeked it as best he could. He put new plugs in it, a new belt and a new battery because somehow my perfectly functioning battery went bad in their possesion. He then proceeds to tell me that he's not completely sure its fixed because today (3 weeks after the initial drop off) that it sounded like there was a bearing noise when it was trying to die, but it should aleast run as good as when I brought it in. So at this point its 6pm, I need the boat back because I'm leaving TODAY and I agree to buying a battery a belt and plugs. In turn I get a bill for 560 bucks. I was so mad that point I just paid it, walked out the door and went home. On the way home I started thinking about this. They sold me a bunch of stuff I didnt neeed when I went in there, I'm now out 560 bucks (dry dock retracted their initial offer to help) my boats not any better than it was....and to top it all off, when i got home and looked at the boat it was compltely covered in black greasy hand prints and looks like hell. I'm 100% unhappy with N3 as at this point they've hosed me for 560 bucks and done nothing but keep me from having my boat until the last possible minute before my trip. I dealt with Luke and Tim at N3. I told them when I took it in that it wasn't a carb issue, but they spent all they're time trying to fix a problem that was not there. They tried to sell me a carb, but couldn't even get it to run on that carb, and to top it off they trashed my boat and killed my battery. Did Dry Dock pimp me sending me there? I'm just absolutely beside myself right now as I'm ready to leave for a trip and the Correct Craft stealership has not fixed my boat, trashed it and charged me 560 bucks for my inconvinience. I left Luke a message lastnight telling him exactly how I felt, but I'm sure I'll hear nothing back because he has never once called me in this entire process. |
Lucas Clark
1992 Sport Nautique |
WOW sorry to hear, if you have some tools at the house and have an hour this afternoon, I could swing past I'm just over here by the airport. If I can't fix it I'm sure I can narrow down the problem so you know exactly whats wrong and needs replaced, It'll Cost you a beer afterwards though, I know it's a steep price but that's my going rate and I'm not changing it
C-Bass ![]() Platinum Member ![]() ![]() Joined: November-18-2008 Location: Columbus, IN Status: Offline Points: 1248 |
Lucas...first off, this sucks, and sorry to hear about it.
2nd off...This is the 2nd time that Chris(79) has offered to personally take time out of his day to help you out...I'm thinking you might want to take him up on his offer. And his rate seems pretty reasonable. |
rogier ![]() Groupie ![]() Joined: September-01-2008 Location: Netherlands Status: Offline Points: 77 |
Incredible, not acceptable and I would expect them to refund. Making our shared problem clear for Eric I would like to share the following:
From neutral to reverse is very smooth. You don't hear anything, revs remain the same and the boat starts backing up slowly. From neutral to forward the RPM drop below neutral RPM. If you leave it at in FWD the engine is struggling at +- 550 RPM and it almost stalls and eventually it does. You have to add some throttle for a two seconds and after that it will run at idle RPM with the throttle in the position it was when almost dying at 550RPM coming from neutral. Once I've been stuck in mud with a 2007 Air and the experience was exactly the same, something appears to be generating resistance. In neutral I can turn the shaft by hand easily and the engine runs great. Does this sound the same for your FWD-idle-problem? |
GottaSki ![]() Grand Poobah ![]() Joined: April-21-2005 Location: NE CT Status: Offline Points: 3338 |
What a maroon, they all clank when they are about to stall. What would he do next, tear apart the engine?
The other carb likely came off some other guys' boat who also wanted it for the weekend. stay clear. |
What is time good for you? Do you prefer 24oz beers or do i need to go to the store and find a different size. I promise whatever size and brand they will be cold. I'll PM you my number. |
Lucas Clark
Spoke with Mark at N3. He was apologetic for the poor communication and the dirty boat. He did feel that his 109/hr labor rate was acceptible and the fact that he charged me 3 hours that resulted in nothing more than replacing a battery that they killed, and replacing a set of plugs that I didn't need was appropriate.
I'm sure I'm somehow atleast partially to blame, but I've been a ski nautique nut (grew up on lake james in angola), my entire life and I'm just beside myself with this situation. Thanks everyone for the input. |
Lucas Clark
Bud select, Bud or Coors
your PM might have went into my spam directory and I can not view them on my cell phone or at work so call me at 765-425-5744
chris p.s. I leave work at 3:00 so i need to hear from you before that. |
Pete,
Pending any engine tuning issues that might cause this, you sure seem like you're on the right track with the trans. issue causing this. Are there any pressure taps on that transmission that you could throw a gauge on so you could verify that no pressure is getting to the reverse clutch feed? |
My feeling is that the cable and carb are out of adjustment a little and I'm going to start there and then move forward, only downside, working in the driveway and no load, Hopefully Eagle creek or another close by pond has a ramp to back the trailer down so we can load the tranny and verify it's working. |
The no load in the driveway may actually help you narrow it down to engine tuning vs. transmission issue. If it's still stalling out of the water with no load when you shift into Fwd., then it may be time to ship the trans to Ohio.
Either way, good luck, and good on ya for personally going and trying to save his trip to Dale Hollow. ![]() |
well hopefully he calls pretty soon, I can't get to my yahoo account here at work and usually the CCFan mail goes into the spam folder and I can not get to the folder using my cell phone only the inbox and I haven't seen anything.
I personally dont think its a trans issue,
it would be nice to have a live feed......lol, decription is key, but he does mention resistance and honestly there is more resistance in the trans when going into reverse. in forward everything is locked and only 2 bearings spinning....you have to take into account thrust, in and out, its possible that a needle bearing from thrust forward is creating the resistance. get 79 down there and let him take a peak. if i was a betting man, its something simple |
That and he states he can drive out of it with a little throttle too
horkn ![]() Platinum Member ![]() ![]() Joined: September-10-2007 Location: Cedarburg, Wi Status: Offline Points: 1511 |
Chris, do PM's actually work for you on CCF? Sending an email through CCF does work, but the PM section does not operate for me, or for many other people on CCF.
I sure hope this is something simple, and if it is, why the hell can't the dealer fix it? It's unnerving to hear that they will change plugs batteries and carbs on a whim. Sure, they love to do that, it makes them money. |
bump |
kapla ![]() Grand Poobah ![]() ![]() Joined: March-27-2008 Location: BA, Argentina Status: Offline Points: 6148 |
He is online so I wonder why he ain´t called ya by now?
hope to have news here... |
Ok, got a hold of chris. You guys are great!!
Lucas Clark
Don't get us started.... |
Might wanna have a camera handy and post some pics of the gathering!!!
CCF members meeting to help each other are way cool... |
not sure if you want to see our sweaty aces it's smoking hot today and the humidity is out the roof. Heading over that way now so I'll see what's up.
Notice I said "dealer"? ![]() |
i´m freezing down here so some guys in sweated t-shirts is a nice turn on for me..
that is just sick in so many ways. But What I found yesterday was, a loose, cable on the new battery install, a loose spark plug, and several loose carb bolts, and throttle cable adjustment issues as well. So what I feel was the main issue and I hope I corrected the issue since we didn't water test it, but the cable adjustment being off actuall was pulling it off the idle curcuit and I think there might be some varness on one mixture curcuit, so I made some adjustment to the carb and linkage and hope all is well. I pointed out a couple things for him to check and adjust once he's on the water so hopefully they no issues on vacation. |
Chris, It sure was great of you to help out. Nice. Sure sounds like N3 put the kid out back sweeping the floors on this one! ![]() But, it looks like they still charged full rate!!:
87BFN owner ![]() Grand Poobah ![]() ![]() Joined: August-25-2006 Location: Ypsilanti, MI Status: Offline Points: 2194 |
Hope his vacation is goin well..
Great job Chris, on going to help him get her running. |
well I'm a little worried actually. Monday laying in bed trying to go to sleep, I start to question myself, did I leave the inspection cover off the packing gland or did I re-install it, did he remember to check the adjustment and attach the saftywire after I tighten it up and explain to him how to adjust it and hope I left it off to remind him to check it when they got there.
I'm worried it backed off while he was driving then when they got back to the dock or house boat and it took on water....little anxiuos to say the least. |
Update
Boat ran and did not sink. Not sure the packing nut is exactly right, but its good enough for now, though there is a bit of a story to tell with that. I'll print off a tutorial and set it up again for good measure next time out. I think the carb, while needing some adjustment and a good cleanup up is fine. I still think theres something lugging the drivetrain in FWD. When it engages is drags the engine down 750 to 1000 rpms causing a need for a 1200-1400 idle. We did this and it worked good enough all week (read not stalling on every engagement). Thanks to chris for stopping by and giving me the newbie once thru on nautique as I've still got a lot to learn. Now I got to get caught up on work here. |
Lucas Clark
can you get under the boat and spin the prop easily with one hand?
Page <123> |
