red kneck engine hoist |
Post Reply | Page 123> |
ripsaw
Groupie Joined: April-04-2008 Location: United States Status: Offline Points: 86 |
Posted: April-08-2008 at 1:45am |
Is there a patent on these or is this an original?
ripsaw
sweet finally got a picture to work, now if I can figure out how I did it.
Tim D
Grand Poobah Joined: August-23-2004 Location: United States Status: Offline Points: 2637 |
A piece of wood under the bell housing would be a lot easier wouldn't it?
Tim D
ripsaw
I saw a post with a cumalong on a pylon, so I thought I had to be able to move it up and down. I thought it worked pretty slick.
69 Mustang
Senior Member Joined: April-26-2006 Location: United States Status: Offline Points: 402 |
This here is a redneck hoist:
Before you give me a hard time about the boat in the picture, please review this post Thank you, Mike |
For every complex problem, there is a solution that is simple, neat, and wrong.
"Where the **** are we?" Amelia Earhart. July 2, 1937 |
ripsaw thats a pretty nice hoist, the straps are a bit redneck but the aluminum sawhorse is just too nice.
rip....you better be changing that ugly damper too...pull it off, you will regret it if you dont....punch in dampers on the search feature and read the causes and effects of a bad damper
BTW, nice jobs on the hoists
Looks like they're going to have to put some cement blocks under the legs if the engine's going to come out. Is that boat a special anniversary addition? |
ripsaw
69 that is a redneck hoist, did someone do the math right? Looks like it might be a little to short to get it out. eric I figured you say that, do you want to just send one back with my tranny? p.s. I'm still stoked I got a picture to work.
Barracuda
Nice hoist job. I especially like the can of cheap beer in the photo! PBR is my beer of choice of working on boat projects
Next time, it may be easier to use 2 bottle jacks underneath the exhaust manifolds. A few guys on here swear by that method (never tried it myself). -Brad |
Pabst who owns the Schlitz label is test marketing the original version of the Schlitz brew in hopes of bringing back a "economical" beer!! I'm one who swears by the bottle jack trick!! |
real men such as myself lift the engine by hand and block it,lol if you believe that one I'll tell you another, sometimes it is possible to lift by hand it depends where the front mounts are and the balancing point
ripsaw
I didn't realize there was any other kind of beer. I like the bottle jack idea, but i've got more ratchet straps than bottle jacks.
i miss schlitz and p.o.c, last resort which is what id do on v-12 cats and it works on these boats as well is to remove the back mount adjusting nuts on the top of the trans bracket, loosen the front pinch bolts and use the back remaining adjusting nuts, the ones underneath the mounts to raise the trans by turning them cc and then block the trans and bring the nuts back down....learned this method accidentally because i forgot my come alongs. works very well
peter1234
nice hoist where did the swings and slide go
for a minute Pete i thought someone contracted you to build them an a-frame
farmer
Senior Member Joined: July-23-2006 Location: United States Status: Offline Points: 442 |
I can draw up some plans for this one if anyone needs them. Farmer |
does the name farmer have anything to do with this? lol I'll post some pics tonight of how i am lifting a 25 bayliner, your gonna ***************, compared to your feat of engineering, you will change your opinion of me
Barracuda
Gary- Like the engine crane system you have there. I was thinking the other day that a couple sections of pipe staging with heafty boards spanning two sections would make a pretty good boat or engine hoist system.
-Brad |
farmer
Brad,the staging idea should work great.A couple of braces to the ground like I used or an X brace between the staging would be good. Eric,I look forward to your engineering mastery unveiled for all to admire. Farmer |
Chopper
Gold Member Joined: June-15-2006 Location: Australia Status: Offline Points: 821 |
the redneck math looks spot on. All you have to do is take off the wheels and drag the boat forward on the concrete.! Simple. |
Farmer, it really is safe i think the way i do it, everyone says it isnt but i go under the boats all the time. I put the transom on my car lift and will lift the front with a forklift and go as high as i can. the Bayliner was pushung it though cause it weighs 7500lbs
as you can see the cheap Bayliners dont have a lift eye up on deck so i had to use one fork on the front ring. at this point i will inch the car lift then the forklift until i get close to the ceiling and try to block |
BTW for you guys that paint thier bottems if you notice the copper paint on the boat bottem, it is a high teflon content bottem paint, it is actually smoother than the gel and sprays on as smooth as the gel. the actual color is blue and will turn color when submerged.
Eric, I think OSHA would have some nice things to say regarding your technique! I have to look it up in my 29 CFR part 1910 standards! I seem to remember a general clause about using lifting devices outside of their intended design.
nothing a hundred dollar bill couldnt take care of
there is a hole in the end of the fork that the ring is sitting in, im not that crazy
I think the number of employees needed at a workplace is 10 before OSHA can come in so you probably have nothing to worry about. If you do ever run into a OSHA inspector, DO NOT consider the 100 bill trick! We would end up getting a collection of money going here with our members to bail you out of a federal jail!!
it would be a gift
