What are these? :) |
Treybizttu
Gold Member Joined: October-02-2014 Location: Grapevine, TX Status: Offline Points: 534 |
Posted: March-17-2015 at 12:26pm |
So i'm piddling around at the office this morning and my boat isn't here for reference so I'm trying to identify plugs. Nothing was hooked up on my boat/old motor when I bought it so some of this will be on a learning curve for me. If anybody has pictures of their GT40 harness all hooked up that would help as well. I found the wiring diagrams for the boat, dash, and what not but nothing that identifies these.
I know the big plug here is in the hull and main my harness to the motor... Not worried about that one. What are the two other ones? Then there are these two that aren't hooked up to anything. And then there are these... I believe these go to the two little terminals on the top of the trans. I'm sure if there is an orientation for them or if they can go on either side. |
nuke_mustang
Newbie Joined: March-09-2015 Location: South Carolina Status: Offline Points: 18 |
I am not 100% sure, but based upon my experience so far, the boat has a "generic" wiring harness put in it to accommodate pretty much anything option wise. I have looked at the ones for my boat and there are leads for docking lights, other interior lights, others that are not connected to anything cause mine does not have those installed. I have noticed a few in the engine bay too, but that maybe to accommodate the ZR6 motor and any sensors that motor has that my EX 343 does not.
So those maybe wires that would go to the other transmission/motor gauge option for that year? |
Treybizttu
Well, this is the actual motor harness and more than likely a ford product rather than PCM or Nautique.... But, that can also mean the same thing in the opposite direction. I.E. the motor harness was made for a truck that has different needs than a boat. A/C, Heat, Transmittion, ETC...
jhersey29
Senior Member Joined: February-20-2014 Location: Colorado Status: Offline Points: 272 |
Shared files from OneDrive http://1drv.ms/1FwUtWA
Dig in the photos and zoom. Everything is labeled on the wires. If you can't find one pm me and we can Skype in front of both boats to follow the wires. http://1drv.ms/1FwUtWA |
Treybizttu
Thank you very much... This helped quite a bit. |
Treybizttu
jhersey29
I have my finger on the one I think it is. The other 2 wires in your bundle match that same bundle on mine. The brownish one with the small black rubber connector doesn't go to anything on mine. The plastic connector is connected and the remaining wire appears to connect to the 60amp breaker with the red and orange wire. I think we're looking at the same wires. Starboard side by the fuel pressure regulator? Would be scary to mess up anything on a 60 amp breaker.
Treybizttu
Yep, Looks to be the same bundle... But, I went through your pictures and looked at the two additional wiring harnesses I have here and none have that plug? Just my new to me motor/harness.
Weird. I'm headed out but I will see if I can better some pictures with better light before I leave town. |
lewy2001
Trey is it a purple wire ??
If so it maybe the EEC power wire PCM did a retrofit of this circuit. Deleting a fuse in battery box with the wiring running to ECM at rear of engine. What year boat did the GT40 come from it may have still been running original fuse in battery box. Have a look at this thread GT40 EEC Wiring Retrofit |
Treybizttu
I'll look when I'm back at the motor...
Motor is a 98 and boat is a 2000. |
jhersey29
I tried to find a matching connector like yours with the orange circle on that wire and couldn't find anything that looked like it. Color of the covered wire would definitely help. The only thing close in shape was the connector for the fuel injector wiring harness to the main wiring harness. That however has 3 wires I believe and is about twice the size. The boat in my pictures is a 1999. Next week I should be out on a buddies model year 2001 with GT-40 and will see if I can see anything if you don't resolve it by then with other members taking a peak at their motors. |
Treybizttu
Treybizttu
The wire going into the plug is dark brown. I need to see if we can trace it back to a specific breaker or relay.
It looks like the connector in Lewy's retrofit thread so I wonder if it's the secondary EEC power supply and just different color? |
Treybizttu
Oops, it was dark enough purple to look brown to my buddy.
Treybizttu
Followed your right up Lewy and it worked perfect!
Bri892001
This looks like the neutral safety switch wires I know that. You already got it started, so looks like I'm late to the party. Yup, they are interchangeable, meaning either could go to either post on the switch. |
