  New Posts New Posts RSS Feed - 85 ski nautique 2001 overheating
WyoLucky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WyoLucky Quote  Post ReplyReply Direct Link To This Post Topic: 85 ski nautique 2001 overheating
    Posted: July-14-2012 at 8:30pm
Please help. I bought a 1985 nautique 2001. It stays about 150 when idling in the water but when running hard across the lake it gets up like to 200 and wants to keep climbing. When you stop back to a idle it cools back down to 145 to 150. Does anyone have any suggestions. I've replaced all the hoses that's about all I've done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2012 at 8:35pm
Overheating at speed is usually and indicator of a impeller that needs to be replaced. You mentioned hoses but not an impeller.
Welcome to CCfan. We love pictures and also suggest you make a diary entry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WyoLucky Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2012 at 9:00pm
The guy I bought it from said the impeller is new but think I'll check it myself. Does anyone know what the timing and points are suppose to be set at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2012 at 9:27pm
Travis,
Do check the impeller but you should know that when running hard the temp will climb. However, 180 would be the norm. 200 is certainly past that.
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2012 at 11:15pm
Pete - Mine never goes above 160F. So he must have a worn pump. or a 160* 'stat.
critter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2012 at 11:35pm
Travis,
There is a 302/351 Service Manual in the Reference section
Timing is 10 degrees BTC at 600 RPM
Point Gap is 18
Dwell is 24-29.
Download the Manual as it has great info.
Welcome to CCF.
1980 Ski Nautique
1966 Barracuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote WyoLucky Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2012 at 3:45pm
Thank you guys for the help I'll try this stuff
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2012 at 6:45pm
Also, check for restrictions (gunk) in your raw water strainer.
You may have already looked here if you did your hoses, but look for gunk in your tranny cooler, where the water from the lake enters into it.
