Motor not going over 3200 RPM |
Author | ||
Rev Bob
Groupie Joined: March-11-2012 Location: Left Coast Status: Offline Points: 45 |
Posted: April-04-2012 at 3:55pm |
I love it when a plan comes together with a simple solution!
Under torqued......Or loose plugs? |
Cheers,
Rev Bob "if it's gonna happen, it'll happen out there!" ~~~ My Dad always said; "Everything on your boat is either broken or about to be....and you just don't know about it yet". **** |
Bri892001
Gotta love the fixes that don't cost anything
00cls1camaross
Senior Member Joined: June-23-2011 Location: Tempe, AZ Status: Offline Points: 123 |
So as it turns out, this was my fault and had to do with how much I torqued the plugs down.
So, when you change plugs, make sure they are torqued down enough otherwise this will happen. What I thought was a smooth idle on this boat was actually very rough. I can hardly hear this thing have any sort of lope at idle with the new plugs and torquing them down enough. |
2002 Chevrolet Silverado Z71
33 x 12.50s, BBK, Cranked 2000 Camaro SS Cam, Slicks, Boltons, Stall 1985 Ski Nautique MT1, Board Rack, ACME 542 Future:Stereo, Wrap, Girls |
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
remove distributor cap and clean the pickup and inspect
Brian
peter1234
Grand Poobah Joined: February-03-2008 Location: United States Status: Offline Points: 2756 |
you need to find out if the secondaries are allowing fuel through them . if you have a stuck needle or a blockage somewhere then they might open but cause a lean condition.
00cls1camaross
I finally had a chance to take a look at this. I watched the mechanism that opened the secondaries and when you would go wide open throttle, it would open the secondaries up and then it would close it. While the secondaries were open (which was for all of 4-5 seconds) the boat sounded like it was missing. Thoughts?
00cls1camaross
Thanks guys. Ill keep you updated.
Jllogan
Platinum Member Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
Good point mechanical advance could be sticking. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21134 |
Nope. Assuming you dont have a clogged arrestor (in which case you may notice a little better performance). Of course, theres no need to pull the arrestor to check on the functionality of the secondaries. I wouldnt recommend sticking your face down the throat of the carb while its running. Driving across the lake at 40mph with an open motorbox and toying with the carb is where I draw the line from a safety perspective. Initial timing should be 10 deg... final should be approaching 35 deg (at 3000 RPM and above). That would be a good thing to verify. |
Jllogan
10 degrees BTDC |
Bri892001
True, true. Does running without a spark arrestor effect intake air flow stuff at all? Obviously not a fire issue with the motor box removed. |
As inboard owners, we have the distinct advantage of being able to just open the motorbox while underway. Having a second person available to watch the engine and probe the secondaries at speed is much easier than the tricks described for a car. |
Bri892001
To check if your secndaries are opening, go to this site:
http://www.bob2000.com/carb.htm And do a control F for the phrase "How to know if your vacuum secondaries are opening" |
00cls1camaross
Ok I am taking this to a buddy to look at tonight. What should the timing be? I figure we can check that too.
eric lavine
secondaries, thats right where about they should be opening
Also, what prop is on the boat? |
00cls1camaross
Ok so I regapped the plugs to .40 and it didn't help much. The boat started a lot easier and idled a bit better, maybe it was mental?
It would run smooth to 3200 RPMs and do the same thing it did last time. Any suggestions. |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5313 |
Just be careful when you regap. I had a misfiring problem AFTER I changed the gap on the plugs and boat was running like crap. Put old ones back in to see if the problem fixed itself which it did. I obviously damaged one of the new plugs when I regapped or when I removed it. No visible damage on any of the plugs but one musta been cracked internally to cause ignition problems.
Just be careful when removing or re-gapping. |
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4243 |
Regap is fine, since nothing else changed that's the place to start, plus it's such an easy adjustment.
Dreaming
regap is fine.... Use a feeler guage to verify the gap, and make sure the tip is straight after you finish tweaking on it.
00cls1camaross
I think the gap is the issue. Do you think I can just regap the plugs I have or should I buy a new set? |
00cls1camaross
I did not do the conversion, the PO did it. The motor ran strong to 4400 rpms when I test drove it. I do not know how to check advance on the timing. I have a buddy that does. I will probably take it to him if I can’t get this fixed. |
00cls1camaross
I am nearly certain I did not cross one of the wires. It does not idle rough at all and runs really smooth until 3000 rpms. I verified that all wires were on the proper cylinder and connected. As for the carb, I do not know enough about carburetion to know if the secondaries are kicking on. |
SNobsessed
EI is not exactly the same thing as HEI, where .060 gaps was common.
I'd reset gap back to .035 & see what happens. Check to see if you are getting gas thru the secondaries - maybe the needle is stuck in that bowl. |
eric lavine
if plugs are white, lack of fuel. if plugs are black, lack of spark
Luchog
Check the wires. Plug gap seems pretty steep. .45 sounds fine.
NG,
Did you do the EI conversion? Did you get the timing light out and check the timing? Is the mechanical advance working? Who's conversion did you use and why did you do it? |
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
Plug wires? Are they on right? Did you cross one of them? Are the wires on all cylinders? If so are your carb secondaries kicking in? Just a few suggestions.
00cls1camaross
So I took the boat out to the lake today and the motor would run above 3200 for a few seconds, sound like it was missing, and then would come back down to about 3000 rpms. It seemed like anything above 3000 was causing the motor to miss.The motor has fresh 91 and is filled with brand new sae 40 oil. The pressure was good and the the water temp was about 150 the entire time.
I changed the spark plugs and gapped them to .55 because I have electronic ignition. I am thinking it may be a plug issue. Anyone have any input |
