  New Posts New Posts RSS Feed - Draining Battery
Draining Battery
Mike View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Quote  Post ReplyReply Direct Link To This Post Topic: Draining Battery
    Posted: August-10-2005 at 12:42am
I have a 96 Sport Nautique, after it sits for a few days the battery goes dead. When I run the boat it does fine, the alternator is charging the battery, but when it sits something is draining the battery. I always make sure all breaker switches are off as well as the radio, any sugestions?
JEFF KOSTIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JEFF KOSTIS Quote  Post ReplyReply Direct Link To This Post Posted: August-10-2005 at 12:57am
Need to disconnect the battery and put a amp meter in series. You can use a regular VOM for this. This will tell you what the draw is. It should be less than 15 milliamps (ma). If its 500 ma (or 1/2 amp), it will flatten the batt in a few days. Ive seen alot of these problems to incorrect connections made to stereo systems.
