No spark! |
Post Reply | Page <12 |
MdFooter
Senior Member Joined: January-30-2008 Location: Lakeland, FL Status: Offline Points: 100 |
Dude, he did that 11 posts ago, try to keep up.
wakemeup
Senior Member Joined: July-11-2008 Location: Culver City, CA Status: Offline Points: 113 |
Yes I moved the ground. I bought a bigger ring terminal and soldered the ground (brown wire) to it and then ran it to one of the unused threaded holes on the block that you said and attached with a bolt and washer. What do you think of the numbers I'm getting from my coil, that is 12 volts on either side with ignition on and then it drops to 8.5 on either side with engine cranking? I just read the post from MADTOWN78 where he is asking for advice on a new coil and you commented that the wiring harness could have all kinds of screw-ups from previous splices etc. I'm thinking I might have some issues here as well. What do you think about putting the old distributor in just to see if I get a spark? I'll have to get new points, but their cheap. Thanks |
Wakemeup
1988 Ski Nautique 1999 Air Nautique |
wakemeup
Amazing how different my numbers are from yours. I'm going to try to get another set of eyes out here to look at this. Thanks for your help. |
Wakemeup
MdFooter
George,
You shouldn't have 12V at the (+) coil if you have a ballast resistor. The resistor cuts down batt voltage on it's way to the coil so you don't cook it. Trying the old distributor again may at least narrow things down a bit. |
wakemeup
I know its been a while but I finally got a spark on my boat after not touching it since August. It turns out that the brand new distributor I bought from SKIDIM was dead. Prior to finding this out I called Vince at SKIDIM and told him about all the problems I was having and he offered to test the distributor on one of his test engines. So I sent it to him and sure enough it was shot, so he sent me a brand new one and I took him up on his offer of testing it on his engine prior to sending it to me. He did that and sent it too me. I finally got around to installing it today and got a spark right away.
The moral of this story and I know the Grand Poo Bahs have preached this: JUST BECAUSE ITS BRAND NEW DOESN'T MEAN ITS GONNA WORK! However I still couldn't get the boat to start. I have a newly rebuild carb on it and need advice on initial tuning. I am going to start a new thread. Thanks again for everyones help. George |
Wakemeup
H2oXtremes
Groupie Joined: December-03-2008 Location: Mayville, MI Status: Offline Points: 67 |
OK, so I have just installed a Mallory Distributor, using the same hand drawn diagram you used. My issue is that once wired I went to turn the engine over and it sounded like the solanoid click or pop and then i lost all electrical power. The boaat didnt even get a second to turn over an inch its like as soon as I turned the key it just popped and now I have nothing.
my pic shows how I have my system wired, now granted before I did this the previous owner did not use the outgoing side of the resister or shall I say nothing was even connected to it. except the ignition wire coil wire on one post. So I wired it like the instructions said my pink wire in the picture is going to the positive side of the coil, the blue wire is connected to the red wire of the distributor, the orange wire is the ignition. The old distributor had two wires and both wires went to the coil negative and positive. Any help would be great, I have a dead boat at the moment Wiring |
1985 Ski Nautique 2001
Duane in Indy
Per Mallory instructions:
The three wires from dist . RED to 12 volts from Ign. Swt. GREEN to - side of coil BROWN to engine ground + side of coil is fed from ballast resistor |
1978 Mustang (modified) |
Jeremiah2001
Newbie Joined: April-16-2012 Location: Tennessee Status: Offline Points: 29 |
H2Oextremes.
I just went thru the same symptoms your having. I would turn the key over and hear a click and then no power to dash etc... Turns out the battery terminals weren't getting good contact. Good charged battery and good wires but there was just enough corrosion that any draw on the system and it would crap out. Clean your terminals and check your ground wire. Fixed it for me. |
