Dash Switches - 1996 Nautique |
jblake
Newbie Joined: August-10-2021 Location: Minnesota Status: Offline Points: 10 |
Posted: February-05-2023 at 11:44am |
Thinking about summer. It's February in MN... Anyway, several of the push button switches on our dash are a challenge to function. The hardest unfortunately being the Ignition switch which saves the battery between visits. Or not if someone doesn't get it to switch off. I've not been able to find the part on https://www.nautiqueparts.com/my-account/orders/. Any suggestions for a replacement?
Sorry - no pic. I have tried to upload a picture of the dash but keep getting an error. Using a Mac. I've tried Safari and Chrome:
JayBird
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6100 |
Hmmmm. That could be a problem. Maybe you could not find them at NautiqueParts because they are "breakers" not switches. That being said, I went to the website, searched for breakers and 2 came up, 20 amp and 6 amp. But unfortunately they are out of stock/no longer available. That is quite unfortunate as they do tend to wear out and there are a zillion of us out here that use/need them. Hopefully someone else has another lead on them. As far as posting photos, that has been a problem, but doable now. Take a look at this thread. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10666 |
Here are links to a couple of old threads worth reading.
Numerous people with problems with those combination switch/breakers have sprayed a little WD 40 in and exercised the breakers and they've worked like new again. You could call it a temporary fix for a handful of years or so And here's a link to the switches on nautiqueparts.com. if you want new ones Looks to me like they're in stock SkiDim carries them too You can find them cheaper on Ebay too, maybe not all the sizes, but here's an example for a 20 amp ETA breaker With a little effort you can find all the sizes you need, dirt cheap on Ebay. Search for ETA breaker and weed through all the choices. Gotta go, I'm all linked out for now PS..............If you have to turn the ignition switch/breaker off to save the battery, you have other problems like an electrical draw at the dash that's draining the battery. |
jblake
https://ibb.co/BBThZW1
JayBird
75 Tique
But I like ya Larry
I think it's the note that says the one in your picture has screw type terminals used in 84,85 and everything newer like in my link has the push on spade terminals and a higher price to go with them. I think Jay is picture practicing, he's almost got it
75 Tique
If I leave the ignition breaker in the on position the battery will drain in a couple of days too. Mike at N3 told me not to leave it on when I bought it but sometimes I forget.
jblake
Thank you all. I will work my pictures.
JayBird
Here's your picture Here's a little help, like Larry said, click on BBCode full linked, instead of whatever you clicked on before and do the copy and paste and you'll be posting pictures. Look at the screenshot below and you want to click on the gray highlighted copy for the BB code (big red arrow pointing at it) It looks like you clicked on the first one that says "image link" which sounds logical but doesn't work.(at least it doesn't work here on CCF} |
So what makes it drain the battery? |
Don't know and didn't bother to look since if I shut off the breaker it's fine Never could find a complete wiring diagram either
burban65
Senior Member Joined: June-22-2008 Location: NW Indiana Status: Offline Points: 167 |
+1 on the WD40 to aid the function (in / out) of the switch / breaker. It worked extremely well to "free" the switches up. I sold the boat but gave all of the switches / breakers a shot of WD40 again before it departed as a preventive measure for the new owner.
SRB
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21113 |
Agree with ken, I never shut that ign breaker off. Assuming the later 90’s boats are wired the same as the late 80’s and early 90’s, it’s technically not an ignition breaker btw- it cuts all (batt) power to the dash as well as the downstream ignition circuits. Which includes everything that’s switched- most notably the bilge pump. Considering people moor their boats, I’m fairly certain the intent is not to turn that ign breaker off very often…
jblake
Gentleman we purchased the boat from recommended it. Said battery would not last long otherwise. Our boat is on a lift. I certainly get your point about the bilge pump and would have to track down the source of the power drain if it was not on a lift.
JayBird
Lift kept here also. Would bump that problem up on the priority list IMO.
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2857 |
I installed a battery isolator switch on my 1994 Ski Nautique. I kept the dashboard ignition switch / breaker in the "ON" position. When I put the boat away for any time longer than a day or so, I would switch the isolator to "OFF". Worked well. Never ran the battery out of juice with that set-up. I like the option of having the battery completely disconnected from everything.
So I guess that if your new truck or Gary's older truck ran down the battery after a couple days of being parked, the solution would be to disconnect the battery ?...............or maybe find the problem and fix it?
63 Skier
This has been discussed a bunch of times, worth repeating. While I think it was a mistake on Nautique's part to let the bilge pumps be switched off with the ignition breaker, that's water under the bridge/over the dam. The fact is if you click ignition off, bilge pumps are off, leaving your boat at high risk if in the water. I leave my igntion on any time except when on the trailer, and sometimes then as well. I don't know how long the battery lasts, in my case I know I've gone 10 days between starts and fired up ok, though I'd say a noticeable bit of battery drain at that point. I also had a family member and a few friends switch it off, saying "you left that switch on, I saw the red light, didn't want your battery to drain." I saw or heard it within an hour of happening so no big deal, but worth letting others know to leave it on as well.
mrhemi
Newbie Joined: September-02-2009 Location: Canada Status: Offline Points: 28 |
I have a '89 Ski Nautique. Barn find from one owner (my father). During the efforts of revitalizing this boat, I have found in his notes that there were questions of electrical issues killing the battery when it was new. I have just replaced all of the breakers/switches with new (they are available) and discovered a drain with the ignition breaker on. What I discovered, as I heard it, barely, is a second blower located in the bow behind the foot well. This is in addition to the blower in the engine compartment. The blower in the bow runs as long as the ignition breaker is closed. It does not have it's own breaker/switch as the engine compartment blower does. This bow mounted blower is not identified on the '89 wiring diagram that was supplied with the boat documents. I believe this was the source of the mentioned electrical problems 35 years ago.
You know you are getting to be vintage when someone says "Back in the day..." and you can dispute their facts.
Mr. Mike. |
63 Skier
I've never heard of that 2nd blower, wonder if it was added later. Can't imagine what it's doing unless someone thought they needed "ram air" supplied to the doghouse through the hull. No way any sort of blower, or always on motor, can be switched by the ignition switch since it forces you to turn it off and kill the bilge pumps (assuming all these boats were wired similarly). Wiring is sketchy in any of these boats, specifically attention to adequate dash power feed and ground, many people improve them. Not that undersized positive or ground to the dash has anything to do with battery drain.
mrhemi
It came that way. My father was the original owner and he picked the boat up at Midwest Correct Craft in January 1989. I was the original owner of a 1983 Ski Nautique and the blower (single) was located below the deck in the bow and ducted through the hull. it wasn't really very effective, especially if the engine cover was up. When I saw the '89 had it adjacent to the engine I figured they moved it for better efficiency, not realizing immediately that there was a second blower that runs continuously.
Mr. Mike. |
Since picture posting is pretty easy these days............how about a picture or 2 of the front setup and it's associated hoses on the 89 ?
BTW Most people found their 83 blowers mounted under the rear deck above the gas tank
mrhemi
My '83 was an early build 2nd or 3rd one. Originally built for Mercruiser with a Mercruiser 350 in it. That may account for the different blower location. I work an photos.
Mr. Mike. |
LooseScrew22
Groupie Joined: August-05-2022 Location: Oregon Status: Offline Points: 47 |
this is slightly off the original topic, but i need to replace the dash panel on my '95 SN- the original has broken 2 of the mounting tabs. I don't really like the look of the nautiqueparts replica- anyone had success finding an alternate replacement or decal like the original?
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 941 |
Let's see some pics. I would think you could repair with Epoxy, especially if the tabs are hidden.
LooseScrew22
Tried to attach picture, but i get an error. Additionally, you can't see the damage so well from the photo i have. The damage is to the upper/lower screw mounting holes closest to the steering wheel. Even if i could repair the plastic panel around the mounting holes, the decal is cracked and missing a few small pieces and sunfaded. I was hoping to replace the entire panel and remount the switches.
Don't know about anybody else, but I'm still waiting on some pictures of the hard wired, always runs, mystery blower from mrhemi
MourningWood
Huh...have had '82, '83, '84, '85 2001s...none with a 'secondary' bow blower....
1994 Ski Nautique "Riot"
My 95 will drain the battery when parked if the ignition switch is left on. I do not yet have a batter disconnect in this boat. The drain is my stereo. I switch off the main ignition switch almost every time I shut off the engine when it is going to be parked a while. When we go camping people walking past the boat on the water will always tell me I left something on in the boat if I do not shut off the ignition due to the red light. Had not thought about the automatic bilge being shut off also. That would be pretty easy to rewire on a separate fused line. A future project I guess. At summers end I always unbolt the battery cable and remove it from the battery and when summer comes around the battery is still holding around 12.5 volts so it loses very little.
I would think using WD 40 to loosen up the dash switches would promote dirt sticking to the oil causing the switches to fail sooner than later? I know it displaces water but it also attracts dirt.’ Mark
