Rudder "housing" removal?? |
wetskier2000
Senior Member Joined: September-07-2005 Location: New Hampshire Status: Offline Points: 367 |
Posted: January-27-2022 at 8:22am |
Truck paint is progressing!
Current: 1997 Nautique
Previous: 1987 Nautique 1964 American Skier |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10718 |
wetskier2000
yeah, I used the boatlife stuff. All back together less the mystery safety wire and I still owe it an oil change... I bought a fancy dancy 12v electric oil removal tool after the last change last year but read the instructions this year... It wants the oil to be 104-125 degrees... Guess that'll wait til FL.. Of course, it's best to change the oil warm anyway, but just getting it changed I've always figured is better than not.
I miss the oil drain hose on the pan's plug that the 1987 had...
So..........after all the sealant talk, what did you use when you remounted the strut and the rudder port?
Boat Life, 3M, some other equivalent brand, bubble gum ?
75 Tique
Could be, I am sure there is not a real tight specification for that at the factory, but mine just had one wire through both the tiller clamp bolt and the top bolt.
wetskier2000
I wonder if the rudder had 2 safety wires, 1 on the clamp bolt and 1 on the top bolt.....
wetskier2000
All back together but it appears I have 1 leftover SS safety wire... I don't see where I'm missing the damn thing... I have a wire on the two rudder nuts (top of rudder and clamp nut). I have one on the coupling and one on the prop shaft stuffing box. I didn't see similar holes to wire on the rudder stuffing box... I'm probably missing something really dumb...
I tried a couple things first before the idea of using the wood shims came to me. They cut right through the 5200 on my 95 strut while doing no damage. Glad you won the battle.
wetskier2000
... and a metal piece to protect the hull that my wife suggested.... I sliced, then pried, it hinted at moving. I used a BFH (deadblow), didn't seem to do much... Went back to prying, ever so slowly it started to move but even down an inch or so it still didn't just fall out... continue prying, eventually I could twist it a bit and get it loose enough to pull down on and out...
If you use a heat gun, a hammer or slide hammer, a screwdriver, a chisel and some shingles (shims), a pipe, and a razor knife you'll probably get it out
75 Tique
What a great boat hauler that truck is. Gotta say you had a lot of vision when you started that project. Envious of you guys that have the time-space-talent-resources to take on those kinds of projects. I've got a friend back from my MA days (also on H.A.M.B so you may have seen him there) that has done a few cool projects.
37 Chevy - since sold Drag truck - before Drag truck - after Roadster - before Roadster - just about done He's also done a couple of boats - this Donzi And this 65 Stevens Flattie |
wetskier2000
oh yeah, one more thing... I'm going to try to remove the rudder port this morning....
wetskier2000
I understand the "like the build then give it away mentality"... I used the same theory on several Jeeps for my nieces and nephews... Buford, however, is staying with me for the foreseeable future... As my buddy calls him, he is truly an attention whore. Doesn't matter what I park near at car shows, people just flock to him. The only vehicle that stood a chance so far was a beautifully done 1941 Dodge COE.
I have thoroughly enjoyed the COE build and really wouldn't trade any of it. But if I had it to do again, I think I might look harder for a less rotted starting point. I learned A LOT fixing it which was fun, but it was a HUGE task. This is probably my favorite picture from a car show that my buddy was able to catch... |
32 pages of good reading, but I think unless you're a member there, the link won't work Easy to join They seem to have had some site issues over the years that affected lots of the pictures in your thread, but still a great read and an amazing, difficult project
I don't know if my buddy has a site for his build, he did just finish a 73 buick 455 Stage 3 car, they are usually the ugliest body Buick ever made but his is so straight and the paint so pretty, a dark red and every single part looks like it just came out of the factory. You could not build one this clean for $75,000 It is gorgeous, he did not drive it 200 miles and gave the finished car to his 40 year old son. Heck of a deal, he just likes doing the build and he is retired. I will ask him for a picture of his truck. Last time I saw it the truck looked more like the one in your picture of the flat bed than a finished truck.
wetskier2000
And here's what it looked like before I took it apart for the body shop...
wetskier2000
I see what you did with the truck's name! McD, does your buddy have a build thread somewhere? Carnac is correct... Ford cab, 2002 Ram 1500 frame and axles, 1999 Corvette LS1 under the Peterbilt sleeper, some Studebaker parts, some Isuzu parts, lots of figuring stuff out... 32 pages of build thread live here if anyone has a few days to kill....
https://www.jalopyjournal.com/forum/threads/1941-ford-coe-build.919826/ It's been quite a journey. The steering took me 9 months to figure out... This is what I started with... |
More pictures needed
My buddy Carnac seems to Rick's is a crossbreed of some Chrysler, Ford and Chevy parts (and probably some other brands too) with a fair amount of engineering and fabrication involved |
Beautiful project, my buddy is building a COE also, he bought an original with a flatbed on it for hauling cars then he bought a low mile motor home with a 460 Ford powertrain. He is blending the two, it will have the Old Look with the modern Ford 460 powertrain and running gear from the motorhome. ( motorhome had an on board fire that totaled it so he got the package cheap but had no engine or running gear damage )
I keep telling him to install a Diesel so he will have more power and MPG. Those old cab overs have really taken off, they make beautiful and rare projects that people remember.
wetskier2000
wow, that's an EARLY pic, no motor, crusty fenders, unpainted frame... that had to be about 2012 or 13... It's 4 wheel drive and I intend to tow the boat with it. Not sure if it will make FL trips or not... Funny you wonder about it being finished... Not quite but getting close. It's at the paint shop right now and should come out looking like this photoshop...
Rick
Been doing some reading elsewhere U seem to have quite a project going on, maybe finished ? Ford COE that was Old Rusty and Dilapidated I'll bet people would be interested in hearing a little about what I'd call a huge undertaking PS Nice boat in the background
wetskier2000
.....I really like the let it dry idea instead of wiping the excess off... just ask my work jacket I was wearing under the boat the other day..,,,,
wetskier2000
yes.
My dumb questions usually are centered around what makes the most sense for me. Can I accomplish the task in question successfully. What order is best to do these things... If I have to prioritize and leave things until after FL, how can I do that... For instance, I was very grateful to know that I could do the strut bearing without removing the coupling from the prop shaft. Despite the great idea on here to remove it, I pictured that as a really possibility of a crap show on something that had not been apart since 1997. I truly appreciate the wealth of knowledge you guys have and are willing to share. Thanks! |
While I was sitting back I did a little reading. Here's a link to a Boatlife catalog. Your Boat Life Life Seal sure seems to fit in the category of being the "right stuff" especially if you have it already |
wayoutthere
As mentioned above, shims and tapping them in, spraying brake kleen speeds up the job considerably and using it has never cost me any gelcoat.
Residual 4200 and 5200 come off thin as tissue with a razor blade as soon as you spray the brake kleen.
Imo 4200 is all you need (under the waterline) all your doing is sealing against leaks, the part in this case rudder port is held in place by clamping force. Don't wipe off the 4200 that squeezes out, let it dry then use a wooden toothpick or wooden skewer, shishkabob stick and push it thru the sealant and around the base, it cleans up much nicer with no smearing or bubbles getting pulled in/ material getting pulled out and smeared all over the boat, trailer, driveway and head to toe like it does every time i open the tube. |
75 Tique
Whichever sealant you decide on, make sure it has at least 1,000 ppm ZDDP.
Well, will ya look at that, like most things in life there's more than one way to do the job. Some might be easier than others
Kinda like your strut bearing the other day or the fuel gauge replacement Rick. I guess looking at your different recent threads on the strut bearing and the fuel level sender, I wonder why you seemed to go to the extra effort to slide the strut past the rudder and ask about level gauge removal and install without removing the tank if you were gonna remove the tank anyways to remove the rudder and port? I think I'll just sit back and observe the upcoming what's the best sealer/adhesive discussion
Many folks consider 3M 5200 to be the gold standard.
My company has several "brown water" work boats. On board, I've seen cases of 5200 in the parts room. JQ
wetskier2000
yes, tank is still out.. I was planning on using Boatlife LifeSeal that I've used on other hull fittings.... Not the right stuff?
I was warned on this forum as to how strong that 5200 was so I was afraid I would pull off gel coat using the BFH. If 5200 comes off that easy using the BFH method why bother with the weaker 4200 on install?
