Strut Washer question |
Post Reply | Page <12 |
No you'll still need the adapter, the helm was changed a long time ago to a different style connection- all the newer cables are of that connection. The adapter lets the new cable connect to the old style helm
BigBM
Newbie Joined: October-13-2008 Location: United States Status: Offline Points: 29 |
Thank you for the pics/link! I'll take a look at the rudder port next time I'm at the lake. I did see some drips from the port itself - assuming packing needs to be changed so I'll tackle that at some point but haven't inspected much else around it - didn't see anything visually obvious, but will inspect more. That spot that is chipped in the bilge (see pic) just oozes water from it (when in the water) and is just 4-5 inches to the starboard side - about inline with the middle of the shaft log. I suppose it could leak underneath all of the wood reinforcement from the rudder port and then find it's way out there. |
BigBM
Ah, okay. Good to know. Thank you! I'll hold on to the adapter. So, hopefully just a cable swap, an expensive one
I don't feel you will find any wood at the log. Logs are typically placed inside the hull and then glassed over to bond them to the hull. I suspect there's some disbonding of the glass over the top of the log and that's where the water is seeping in/out. Chip some of the decorative gel off the bilge at the leak to get a better idea.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10669 |
The only place wood was mentioned was the rudder port not the shaft log.
The rudder port isn't terribly far from the dripping spot and the water could be migrating from there under the gel coat. But if the port is sealed good now, it's probably not too likely. I'd probably agree with Pete about the shaft log
BigBM
Thanks, Pete! Will chip away a bit at the leak and see what I can find out.
BigBM
Thank you! I will try and investigate further here too (at/around the rudder port). I'm sure the sealant around the hull/rudder port is the same old stuff I removed from my strut, although I don't remember seeing any obvious water coming in there except for the slowly leaking rudder packing. I still have a tube of 4200 and assume that it wouldn't hurt to pull the whole rudder port out, repack and clean it up and re-bed it with 4200 and reinstall.
If it looks like the sealant on your strut, it wouldn't hurt to do the rudder port now while you're working on things
