Seat Cushion Backing Board Help |
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2858 |
Posted: February-13-2021 at 11:10am |
2001 model year. Ski Nautique Open Bow
I don't know the proper term for the broken piece, so I'll attempt to describe... The seat cushion on the flip-up observer seat has a problem. The bottom of the cushion is a hard piece of some type of composite material that acts as the upholstery staple point and is screwed to the flip-up seat base to secure the cushion. Is this hard piece at the bottom of the cushion called "backing board"? Anyway, the backing board has broken in half and now the seat cushion needs to be repaired. The skins are in great shape, so I removed the skins to expose the foam, plastic liner and backing board thing. The backing board is white and looks to be 3/8" thick or so and seems to be made of some type of composite -- definitely not wood. I need to find a replacement piece that I can cut-to-fit and re-assemble the seat cushion. Any ideas what this backing board is and where I can find a suitable replacement? JQ
JQ,
What you are looking at is cellular PVC. Many of the home improvement stores sell it as PVC trim board.
I have heard it referred to as expanded pvc (or xpvc). I haven’t heard the “cellular pvc” name before. Can you confirm that’s the same thing?
Mikeski2000
Groupie Joined: May-20-2018 Location: Iowa Status: Offline Points: 45 |
I had to replace mine as well. I ordered a 24”x48” piece of 1/2” HDPE on Amazon for like $50. Seems much more durable.
Mike
Thanks Gents. Online, I found both the cellular PVC and the expanded PVC. One vendor here has both so I will take the broken piece and see what looks like the best match. I also may drop by a local marine upholstery shop and see what they recommend.
JQ, Did the vendor have a decent description of both? I did some searching after Tim questioned the possible difference between cellular and XPVC but couldn't find any info. I always thought they were the same??
Mike, Did you have any problems getting the staples into the HDPE?
Mikeski2000
No, but I use a pneumatic stapler. With the way that the seat base cantilever’s over the frame, I had two of the regular material crack. Seems people like to step there when entering the boat off the dock.
The HDPE is a little less brittle, but still vary rigid. |
Mike
Update: The PVC board that I found was not to my liking as it was only 3/8" thick and seemed brittle. Instead, I purchased a 1/2" X 24" X 36" sheet of HDPE for the seat backboard. The HDPE is heavier, but is much more robust.
ChristinesMarine
Senior Member Joined: December-01-2011 Location: Orlando, FL Status: Offline Points: 223 |
Here is a little tip that I used for years. CC used expanded PVC from 92 and up to ? You can repair it with clear heavy duty PVC cement. Apply generously to all broken pieces then clamp together, if clamping isn't possible, lay the piece on your workbench and squeeze the pieces together as hard as you can and have someone tape across the break (s) with duct tape then flip it over and do the same. Let it sit for at least 24 hours. I have done dozens and found the repair was stronger than the rest of the board. I actually tested one and the board broke in other places while the repair held!
Thank you all for the Many Years of Support
~~~ (Retired) ChristinesMarine ~~~ In God We Trust ~~~ |
Thanks for the nice tip. Good to know. JQ
spoink47
Newbie Joined: July-14-2021 Location: Houston, TX Status: Offline Points: 2 |
Have you eventually repair? I faced kinda same issue, so your story would help me out here
Andy,
JQ is a frequent visitor so be patient as he'll be on and hopefully catch your question. Regarding the problem with the expanded PVC backer board breaking, HDPE ia an alternate some have used: |
Andy:
First, I removed the entire seat cushion from the mounting. Then I carefully removed the broken bottom pieces. I laid out the broken pieces to evaluate what I would need. Then I went to the local plastics supply dealer. Impressive outfit...like a big-box store for all things plastic. Anyway, I found a sheet of of white / natural HDPE (High Density Poly Ethylene). I measured the basic rectangular size of the seat bottom that had broken and had the plastic outfit cut a rectangular piece that measured 24" X 36" X 1/2" thick. The HDPE was just regular stuff...not the special marine-grade UV resistant. Back home, I used the old, broken pieces as a template for the new HDPE sheet. I then carefully cut out a new seat bottom using a hand-held jig saw. I should have used a router with a quarter round-over bit to soften the edges, but I simply used a belt sander instead. Once I got the seat base ready, I took the new HDPE seat base and upholstery "stuff" to a local upholstery shop I've used in the past. Total cost was $35 for the HDPE and $75 for the upholstery work. Not too bad. The new seat is much more robust. JQ
I would try the PVC cement and glue it first thats what I did on my '95s make sure to use primer one it before gluing.
