Winterize pump AF no plugs removed |
Post Reply | Page <12 |
How do you determine quality of fuel? Could your poor quality fuel be the result of not using stabilizer? Stabilizer doesn't help when you add it in May after sitting all winter... I don't see what the big deal is about pulling 4 or 5 plugs and a couple of hoses to drain the water. |
If you’re having consistent fuel trouble then consider the possibility that the source may be the problem. Maybe it’s low quality from the outset and maybe it’s been sitting in their storage tanks too long? Establishing a trusted source of quality fuel may take some time but a little common sense may point you in the right direction. Oh you mean stabilizer only works on fuel that hasn’t gone bad yet? Who knew? |
Well the thread is aleady jaxed, so here is my rant- Both myself & neighbor had bad gas this summer. somehow ended up with so much water in it engine (lawnmowers) wouldn't run. I only use non-eth for small engines. I am wondering if the non-eth pump is always non- eth. My neighbor got stung as his rider was under warranty & he just had them come & pick it up. They charged him about $500 for the fuel system overhaul. Never had problems until this summer, just sayin' |
rwittmer
Newbie Joined: June-11-2018 Location: CANADA Status: Offline Points: 39 |
I checked the AF that came out of the manifolds (drain plugs) and tested at -12 degrees C. So I took advice from all here and decided to go to my servicing dealer. Well re-winterized it as per CC dealer and now have peace of mind. The dealer also made me a fair price and will be charging me $450 with oil change in the future.
Thanks to all for the logical advice.
Rene Wittmer
That's only 10 degrees F. I'm glad you went and got the winterizing done correctly. Come spring your may have been very disappointed with that pump through method.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10662 |
Well the good news is that you'll sleep on those cold nights.
What kind of antifreeze was this that you tested at -12 degrees C? RV / marine antifreeze or automotive type stuff? If it's the RV/marine stuff, the freeze point doesn't tell you much at all, you're more worried about the burst point. But the real point is that you weren't comfortable and now you are with your same dealer that did it for years with a warranty to go along with it..
