  New Posts New Posts RSS Feed - Stringers
Stringers
 Post Reply Post Reply Page    <1 8910
Nautiquehunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2021 at 8:12am
The width of the Ski was the same as the Mustang . I hoisted the Mustang off its trailer and set it on the new trailer the bunks line up fine the length is about 15 inches too long . I moved the front stop on the trailer to get 260 lbs of tongue weight level with Mustang on. I don't know how much the Mustang weights but it should be in the 10 to 15 % range. I don't want to cut the new trailer It won't be used most of the time the original trailer will work fine for the 1/10 th mile run to the ramp . I don't trust it long distance.  And you never know what I will come across in the future .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: February-23-2021 at 12:18pm
Looks to be a 1980 or 1981 Ski Nautique.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: February-24-2021 at 6:47am
You got it 1980
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2021 at 8:00am
It was in the 70's and sunny yesterday so we took the Mustang out for more sea trials. Moving the ladder step up worked it now rides bow up . I am getting more comfortable with it but it still rides like a canoe with a V8 in the middle. I am thinking of adding some weight to the wife's side to even the boat out or just get a fatter wife?  So far I need to look at the bilge pump it doesn't work on automatic , the horn quit working  and the oil pressure drops from 50 cold to around 20 hot . I hope its just a sending  unit. Overall its coming around nicely and should be ready for the ruckus in April.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2021 at 8:39am
LH prop going to cause some serious stbd lean issues. Can try adding port weight but I’d keep it out of the nose if you’re not a fan of ATF.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2021 at 10:48am
Option C: get a girlfriend and add her to the wife’s side
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2021 at 8:21pm
Originally posted by Nautiquehunter Nautiquehunter wrote:
The oil pressure drops from 50 cold to around 20 hot . I hope its just a sending  unit.
Are these cold and hot numbers at idle speed or some other speed?
They sound reasonable at cold and hot idle for an engine that's been around for a while like from an 80's Supra
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2021 at 7:37am
Oil pressure drops mainly at idle . Around 20 psi hot goes back to 40 at speed. I am going to hook up a mechanical oil gauge and see what I really have.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2021 at 7:50am
Mike,
From a search:
"The minimum oil pressure at idle is only 5 psi (34.5 kpa). The minimum oil pressure at 2000 engine rpms is 35 psi (241 kpa). Both of these pressures are using a mechanical oil pressure gauge that can measure the low 5 psi readings."
What weight oil are you running?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: February-26-2021 at 8:00am
Carnac here says that another search would tell you that Mike is a Mobil1 15w50 kind of guy Wink
And he likes FL-1A filters to go with the oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautiquehunter Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 7:32am
Bing Bing Bing give KENO a qupi doll.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:41am
I think you really should rename this thread since "stringers" gives no clue as to everything that's now in the thread.
Something along the lines of  "The building of Tweety, my 68 Stang". or maybe "Tweetystang"
Just click on Edit in any of your posts in this thread and you can change the title
I'm figuring you could get plenty of other suggestions also though Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 8:52am
Breadth of info here for a thread titled “Stringers”
Back on page 6
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: Yesterday at 9:09am
Back on page 6
But only one of us suggested a change Wink
Copyright 2021 | Bagley Productions, LLC
