  New Posts New Posts RSS Feed - Just got a dui distributor.
camron18 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Topic: Just got a dui distributor.
    Posted: April-21-2016 at 10:54pm
Ordered it yesturday at noon from summit and already got it today!
Looks awesome My question is should there be up and down play on the shaft to the housing? About 1/16 inch up and down play. It looks like there are set screws to adjust it? Anyone have this?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donald80SN Quote  Post ReplyReply Direct Link To This Post Posted: April-21-2016 at 11:36pm
Steve K. (Air 206) just installed one in his 91 Vee Drive Barefoot Nautique last week. They dialed it in at the White Lake, NC reunion. Go to the White Lake Thread and PM Steve for questions. TBenj and JoeNY are very familiar with their application and operation.
Steve is in Virginia.
You will be in good hands.
Donald
1968 Ski Nautique, Project.
Air206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 1:04am
Cameron:
My Performance Distributors DUI for the 454 was not adjustable. Are there instructions that came with yours for fitment? I was so new at all this that I actually read mine.... I know, crazy - right?.
Mine said that there should be up and down play in the distributor shaft and it should engage but NOT bottom out - as that will cause damage. It came with a flat fiber washer to act as a spacer between the block and the neck of the distributor shaft.
Hope that helps. Look at Jpass' write up for his "ProTec Ignition Swap" . The 454 has slightly different issues and I'll make a modification post sometime soon.
Feel free to PM me.... but I warn you, I know very little..... but it ran! Ha!
JPASS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPASS Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 8:22am
I can't recall if there was any free play on my DUI shaft. I do know that I did nothing to the DUI shaft prior to installation. I'd give Performance a call and run it by them (901) 396-5782.
'92 Correctcraft Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2016 at 2:08pm
i just called them they said up and down play is normal.
Thanks
Siveck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Siveck Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 12:04am
I installed mine in my 351W about 11 years ago and do not recall any play or adjustment. I do remember that the instructions mentioned to bump the starter if needed to engage the oil pump drive and that was one of the top 10 mistakes of my life. The brass teeth on the distributor somehow sheered all but one of the hardened teeth off of the camshaft. Chewed up the brass as well. That is the reason that I now own a cherry picker or engine hoist. Oh, any by the way, Comp Cams has reverse cut blanks that can be custom ground for our reverse rotation motors.
1975 Ski Nautique
"Small Letter Boat"
Orlando76 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orlando76 Quote  Post ReplyReply Direct Link To This Post Posted: April-24-2016 at 12:20am
I seem to recall some play, maybe less than 1/16".
1976 Ski Nautique 351 Escort
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 10:34am
Got the dui installed this weekend and it really does "fire up with gusto!" my brother in law helped me out and made a great suggestion. he said maybe now we should get a new air filter.
Now i got all kinds of random wire harnesses and sensors that are not plugged into anything that i want to get rid of. ill try to take a pic but it seems like i need to keep the electric choke, oil pressure and temp senders. is there anything else?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 10:50am
The only sensor you lost in the ProTec swap to DUI is the knock sensor. You may wish to review JPASS' post as it is a good review of the wiring and diagram.
phatsat67 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 11:01am
120 bucks or so and you can buy a new harness that omits all the old protec stuff.
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 12:10pm
The oil and temp switches and knock sensor are not used anymore. You can cut off all the old connectors just make sure any wires that are still hot get the ends covered in shrink tube, If you used JPASS'es write up then there won't be any hot wires left over.   If you wanted to get creative the oil/temp switches are wired together and could be used to drive an alarm or dash lights (or shut down the motor) if a low oil or high temp condition occurs. They short to ground when a failure is detected so just use them as the low side of the circuit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 1:35pm
I think i have alot more wires than just the ones in JPASS write up.
There are gadgets that are just laying on top of the manifold that have been there since we bought it, the previous owner said they were for the EFI but he converted it to carb, anyone know where i can find info on that?
Also when i disconnected the coil pack the bracket with the starter solenoid and fuses also came disconnected along with another box of some sort. i don't know what that is also.
You can kinda see a few of the plugs im talking about here.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 1:42pm
Ah, this was a TBI to carb conversion as well, not just ignition. Yea, probably more wiring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 1:44pm
I am liking Zach's idea of the harness swap......
N3 will have one that I JUST returned yesterday.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 1:55pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 2:13pm
Looks similar, Mine was a 454, non-EFI - Check with Townsend at Nautiqueparts.com.
He'll hook you up (discount for being a member too)......
(You don't have to swap, though. It gives you a chance to "clean it up", and make sure you don't have resistance issues and voltage drop in an old harness. Mine was good, without voltage drops but I didn't have all that.)
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 2:36pm
anyone know if i can cut and connect to make my own?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 2:48pm
Do you know which schematic matches your harness?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 2:56pm
no is there a TBI schematic?
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 3:55pm
What year and model boat?
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 4:06pm
1994 hydrodyne.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 5:38pm
Not worth the swap out Steve?? I hear it's running nicely after WL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Air206 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2016 at 6:05pm
Definitely not worth the swap. It's all neatly soldered and bundled up now. Plus, I had several non-original senders wired into the Pro-Tec Circuit Breaker which is not accounted for in the new harness.... so I would still have a spliced harness.
Runs AWESOME!
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 2:34pm
what is your electric choke wired to? ive seen some say alternator, some say temp sensor?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 2:58pm
Cameron,
With a carb and standard ignition, the choke is wired into the switched ignition feed from the key switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 2:59pm
Very cool Steve !
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 3:03pm
so it is wired in all the way under the dash? or at the solenoid?
DrCC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrCC Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 3:09pm
Normally, it just taps into the ign fd wire in the harness next to the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote camron18 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 3:10pm
right now it is taped into a wire that runs into a computer that has all the extra TBI harnesses. im trying to take that out. so where would be a good place to connect it to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote phatsat67 Quote  Post ReplyReply Direct Link To This Post Posted: April-26-2016 at 3:24pm
It needs to be connected to the purple ignition feed wire from the dash. A full 12v needs to be sent to the choke so whatever wire you're using to supply the DUI will be fine as long as running voltage is above 12v to both.
