No more hull hugger (fart box) |
Sam B
Senior Member Joined: November-17-2007 Location: StevensPoint WI Status: Offline Points: 393 |
Posted: August-03-2013 at 12:38am |
My brother fabbed up a (fart box eliminator). I will run it in the morning. Should sound good. All stainless construction, mandrel bends, and purge tig welded by a class A certified welder. Former fabricator for RCR nascar team.
He told me if anyone wants one he would put a price together on them. Should fit any boat with the hull hugger muffler (fart box). [/IMG] [/IMG] |
Bri892001
Wow! Looks nice.
Would love to hear how it sounds. |
bhectus
AWESOME! Post a sound clip!
That's Hot.
It looks like he used 400 series stainless muffler components? You may be disappointed in it's corrosion resistance in a marine environment! Check on the stainless grade he used. If it is 400, a certified welder should know better. |
forvicjr
Gold Member Joined: August-24-2012 Location: sc Status: Offline Points: 692 |
Come on pete, why you always have to piss in someone's cornflakes! Hell my pipes are aluminiumised steel for now until I order my copper ones. Great work that I see. Only thing I would have done different would have been a more of a Y instead of kick off pipe. Still great looking quality workmanship.
“Tact is the ability to step on a man's toes without messing up the shine on his shoes.” ― Harry S. Truman
peter1234
in other words the welder you used is a hack and he should probably not be certified is what he is saying in his usual politicly correct gentle way with words.. looks good , if for some reason it only lasts 15 yrs and gets a bit punky looking i am sure you could have another fabricated
forvicjr
LMAO, 1234 pure comedy right thir.lol
"come on" Vic, I'm not "pissing in any corn flakes" but simply pointing out an important point. Why go to the extent of making a great looking Y pipe conversion and not using a the best grade of material?? There are several grades of certified welders but any of the grades should know what material should be used for a marine environment. As Peter mentioned, if he used a 400 series SS, he must be a hack. Sorry, but we'll have to wait for Sam to fill us in on what was actually used. However, I'll bet it's 400 considering the swagged ends and the different diameters used!
BTW, why did you use galvanized steel? Are you shopping at Autozone? |
forvicjr
Pete go back and re read my post. I didn't use galvanized, I used aluminumized, there is a difference. A man of your knowledge should know this.Also its temporary as I didn't know if I would like it and I do so I'll be ordering copper. What im saying though is you should have asked what material after you complemented the qaulity. Then if he replied with inefficient material use inform him then. Not beat the poor guy down before you even know what he used. I tell ya common sence and politeness is scarce. Unbelievable. ...........
Silver15
Senior Member Joined: March-24-2010 Location: Orlando Fl Status: Offline Points: 398 |
Nice! I agree, the hull-hugger does make for an annoying exhaust note in the 2000-3000ish range.
2000 Air/Sport
1978 T16 |
forvicjr
Anyway Sam it looks killer. My aluminumised steel has lasted over a year and with no sign of rust. Yours will last as long as you will probably need it. Great enginuity (spelling?) and design. If I needed that type of setup I would run it. Not going to turn your post into something else.... vic
Florida Inboards
Senior Member Joined: December-27-2012 Location: Panama City, Fl Status: Offline Points: 265 |
Very Cool! yes would like to know cost!
Money Talks! BS Walks! and loose change rides the bus!!!
89Martinique
Senior Member Joined: September-05-2011 Location: Binghamton Status: Offline Points: 457 |
sound clip by chance?
Current Boats:
1992 Supra Comp-TS6M PCM 351w HO Pro Boss Pro-Tec Ignition - Full Composite (no wood stingers!) 1989 (3rd Gen) Correct Craft Martinique B/R PCM 351w Power Plus 1984 E-Scow Keuka Lake, |
Vic, Sorry I missed the aluninized VS the galvanized. Yes, I do know the difference. In a salt spray test the galvanized will out perform the aluminized by far. I understand it's "temporary" and I was just asking why you went with the temporary. Understand it's the inside of the pipe that is the concern and not the outside you are looking at. |
forvicjr
Pete I didnt specify but the pipe is aluminumised inside and out. The reason for this is I didnt want to spend big bucks on copper if I didnt like it. Fourty bucks or way more for copper. See now?
JPASS
Looks sweet. Get that youtube video up so we can hear it.
'92 Correctcraft Ski Nautique
peter1234
are you alright? when in the first post did you ever mention it was great looking. |
I used plain mild steel 90's on mine when I first did it.They replaced the rubber ones that connected up to the risers to make the turn to go under the floor. The rubber originals lasted 18 years and needed to be replaced when I got the boat.The plain steel ones lasted 21 years---
Sam B
Had the boat out tody it sounds kick but!!!I will try and
take a vidio of it next time out. The stainless used on this PROTOTYPE is the cheeper stainless. Yes he did tell me it would show some signs of corosion over time. But I bought the cheeper stuff from jegs not knowing if it would be to loud for my liking or how it would fit in the boat. Now that I know it works and isn't to loud we will make all pipes from this point forward out of the better stainless. I also noticed an increase of power after installing this. So glad I removed the fart box! Pete! You the man!!!! |
Sam B
Pete. If your calling my brother a hack I would put his list of acomplishment against your any day! I know your a very knoledgeable guy. But please don't insult people you don't even know. I don't recal him nor I ever insulting you.
Sam Brundidge |
peter1234
Got Tiques
Senior Member Joined: February-27-2009 Location: Scotia, NY Status: Offline Points: 427 |
Sam,
Sounds like a nice upgrade. Post the price, and some overall lengths, and space between the two inlets, for assurance measurements. Might well be interested. Thanks, Todd |
bhectus
I'm guessing Pete didn't get to ride any inflatables yesterday and may be a little grumpy.
Sam, If you are referring to me and not 1234, keep in mind he was the one who brought up the word "hack".
Nautiquehunter
At the risk of sounding ignorant I have to ask. What is a Fart Box?
Can somebody post a pic so I can understand what you are talking about? |
Sam B
Fart box is a name my kids gave the muffler in my 96. They thought it sounded like the boat was farting at idle. They like the sound of our 73 alot better. Open pipes! I don't have a pic of the muffler at this point but I will put one up tonight if somebody else doesn't Sam |
Pete B, Pete C's comment was a bit sarcastic. CCF loves Pete B but we scratch our heads wondering why you're critical of people actually working on their own boats.
Nauti87
Senior Member Joined: June-05-2012 Location: Central Florida Status: Offline Points: 114 |
There was a brand new SAN hanging out with us today,, it was way too quiet! Sounded like a pleasure cruiser.
1987 SN 2001 Barn Find aka "Nauti" (sold sadly)
1988 MC Anniversary Prostar 190 |
89Martinique
Almost there, just add another 3.5" outlet and your set to be heard over 2 miles!
Current Boats:
