  New Posts New Posts RSS Feed - Ski pylon material
Ski pylon material
Waternut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Topic: Ski pylon material
    Posted: January-09-2013 at 4:32pm
Out of curiosity, are the ski pylons made of aluminum?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 4:49pm
1973+, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 8:05pm
Ok thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-09-2013 at 8:20pm
1973+, yes.
Yes but, I wouldn't make it out of any aluminum. Go for 2024 or even better, 7075.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 12:49am
Thanks. I'm not looking to make one. I wanted a pylon without a ring because none of my friends can figure it out no matter how many time I show them. I bought a SN pylon but the base of correct crafts are greatly different from my own and I need to drill it to suit my needs. If it's aluminum, I can drill it but if it was steel, I knew I don't have that capability and would have to pay someone else.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 12:57am
btw how do you tie the rope on a ring a finger?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 8:23am
The rope goes through the ring and then it's double looped around the finger.
Waterdog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waterdog Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 9:27am
Pete,
   The floor plate on the ski pole is welded 2024 can be welded
but you can't weld 7075. 7075 machines easily and polishes great.
   How do you like 6061 T4 ?
- waterdog -
78 Ski Tique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 9:45am
Originally posted by Waterdog Waterdog wrote:
Pete,
The 6061 is the most common but certainly not rated very high for strength. If you have an older pylon with the welder plate at the floor, then I still would go for the 2024 due to it's better strength.
Yes, the 7075 is a problem for welding but if you have a newer pylon that clamps onto the engine cradle, then I would use it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 4:10pm
2 ways, depending on the length of the loop on your rope.
Top = shorter loop, bottom = ideal if the loop is long enough.
storm34 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote storm34 Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 4:15pm
Not sure what that bottom center image is supposed to represent...who's boat is that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 4:22pm
Spike's orange Skier (not your Promo).
The over the finger method is probably more completely described if you follow bottom left, top middle, bottom middle, bottom right. Rope goes through the ring, back over, then back through the center again and around the finger (then pulled tight).
turningpoint84 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote turningpoint84 Quote  Post ReplyReply Direct Link To This Post Posted: January-10-2013 at 5:27pm
I see a blue wiener with blue balls.
1970 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote Waternut Quote  Post ReplyReply Direct Link To This Post Posted: January-11-2013 at 1:03am
LOL on the blue balls. Interesting that I've never seen the top method before in over 15 years of boating. Guess we do learn something new everyday...
Post Options Post Options   Thanks (0) Thanks(0)   Quote 63 Skier Quote  Post ReplyReply Direct Link To This Post Posted: January-12-2013 at 9:11pm
In all the years we skied on my '63 we just chucked the loop over the finger, never once did it jump off. I don't think it ever occurred to us to go through and loop over except when using it to tie up at the dock.
