'74 Ski Nautique Electrical Issues |
74Wind
Posted: July-12-2012 at 1:04am |
Although many on the site debunk electronic ignitions, I've had a pertronix in my Century for 3 or 4 years and have had no trouble at all. |
1974 Southwind 18
1975 Century Mark II |
79ntique
Newbie Joined: July-09-2012 Location: greenwood,in Status: Offline Points: 12 |
can anyone recommend a reliable electronic ignition system ? When pulling under load, I lose all ignition and I suspect that it could be the ignition module breaking down. When an ignition module fails, is it typically as it heats up and then loses all ignition ? thanks
You could go this route,less money and possibly a better one too.
bobcycleb
Newbie Joined: June-23-2012 Location: Loveland, CO Status: Offline Points: 18 |
I'm by far not the expert on this one--in my case that's not what the problem was. I was told that an older tach can start to draw the power or "ground out" therefore interfering with the current that should be going coil-to-distributor. The test is to simply disconnect the tach wire at the coil and see if you get a different performance. In my case it didn't make any difference because the real problem was the loss of power through a incorrectly installed rubber bushing (should have been a non-conductive nylon type)at the distributor wall. Let me know if that works (the test).
Bobcycleb
Same as you I guess Dave. Made me think, I wonder how he's doing.
OverMyHead
Anybody else do a double take at 79ntiques screen name?
1987 Ski Nautique |
79ntique
I purchased it from a local Nautique dealer 10 years ago, wish I knew the manufactuer. My problems did seem to begin when I made the conversion from points, but I'm not sure converting back to a points system is wise -- thoughts ? I didn't save the old dist. plate, ballast, etc from the points system; thinking the EI ignition would be maint. free.
79ntique
At first, when the issue first started in Indianapolis, Ski Nautique dealership $600, but the problem was not fixed. Since then I had it at a local auto electrical shop and on-the-water boat mechanic. -- problem has gone on for > 5 yrs....
Bob, Fill me in on this theory. |
bobcycleb
Newbie-- another thing you might look at -- I've been told that an older tachometer can go bad and start pulling the current instead of the current staying in the wiring from coil to distributor. Easy enough to check--disconnect your tach wire on the - side of the coil (mine was a gray wire--only other one I had on that side was the distributor wire)and see how it runs. After that I'm out of ideas! Good Luck!
Bobcycleb
Bri892001
You most likely want the coil at the very top or the very bottom of this page: http://www.skidim.com/products.asp?dept=1137&val=0&pagenumber=1 I think it depends on whether or not you are using an external ballast resister. Oil filled coils on their side tend to overheat. Common topic on here. |
Bri892001
You most likely want the coil at the very top or the very bottom of this page: http://www.skidim.com/products.asp?dept=1137&val=0&pagenumber=1 I think it depends on whether or not you are using an external ballast resister. Oil filled coils on their side tend to overheat. Common topic on hear. |
Who's EI did you use? There are some out there that are known bad. Also there are many who do not consider it an "upgrade". |
79ntique
Can you send me info. on the special coil that you mentioned in this post. (I don't see it in any ofthe above messages) I have been using oil filled, on it's side and I have converted to elec. ignition. thanks
DrStevens
Senior Member Joined: October-15-2011 Location: Columbus, OH Status: Offline Points: 422 |
79, where in Indiana have you had your boat serviced?
79ntique
I have a '79 nautique that has been having a very similar problem. Runs good, heat up after pulling a skier, completely stalls, cools and then will run fine for a while after it cools. Unfortunatley I've tried about everything-- upgraded to electronic ignition, removed the resistor, several new coils, new starter solenoid, several boat mechanics and still am having the same problems after a few years. It's almost like there is a dead short, that completely shut down the entire ignition. Yesterday I was running at 5000 rpm and it completely shut-down, cooled and restarted. This is probably not helping, but your symtoms sound familiar-- let me know if you come across anything to solve the problem. thanks
bobcycleb
OK gang-- here's the real story. Upon further testing and review--I had the distributor rebuilt about 4 weeks ago--where the wire comes through the distributor from the points on the way to the coil--the tech used a rubber bushing instead of the recommended bushings. Long story short spark was going from the wire to the distributor casing and we were therefore losing spark. Went insulated wire direct from points through distributor and to coil. YAY-- back on the water. We'll run it for a few days and if all is well I'm going to convert to electronic (Pertronix kit). Thanks for the suggestion--back on skis in the morning! HAPPY 4TH
Bobcycleb
Bri892001
Any chance you replaced on oil filled coil laying on it's side, with a new oil filled coil laying on its side? If so, check out an epoxy filled one at one of the sites Chris mentions above.
I also have the pushbutton dash breakers, its like a switch and a breaker in one. Might be just a late 80s early 90s thing? Also, check out this wiring schematic, to make sure you everything hooked up right: |
bobcycleb
I've got fuses in various places on the dash--above various accessories options--like blower, bilge, misc., etc. I have one fuse with wire and slide on connector that's not being used--I believe that has always been there--it happens to be right above the ignition switch. Just crawled up under with flashlight to double check and couldn't find anything it would connect to--once again these are fuses. Not sure if I have circuit breakers anywhere unless located somewhere else off the engine. All accessories/gauges are working properly (doesn't feel like any blown fuses). Next idea?
Bobcycleb
I could be wrong due to your year. Mine has circuit breakers on right side of dash. You still could trace the voltage drop back to battery.
bobcycleb
Where's the dash breaker? I already replaced the ignition switch!
Bobcycleb
A long shot - the dash breaker or key switch is failing after a period of time. You might want to use a voltmeter to see if voltage is dropping off, then trace it back to the problem.
bobcycleb
Hi gang-- hope all are having a GREAT day! Been playing with my boat for about two weeks--thought it might be fuel line, carb, etc. By process of testing, replacing parts,etc. have determined it's something electrical. Ford 351.
When we start up and idle--after a few minutes or if we run the RPM's up past 2500 we start to and lose spark--at first feels like missing a bit, then dies all the way--won't spark on retry (turns over fine). After cooling down will start again. Went to new coil (yes--12 Volt and must be used with outside resistor). Went to store bought ballast resistor. Same results (put original ballast resistor back on--looks beefier). If we run a wire from positive side solenoid to positive side coil it will start and keep running. When using a volt gauge (friend helping) we got 12 volts off one side of the resistor and only 6 on the other side (side that goes to solenoid). Battery putting out 12 volts. Had the distributor rebuilt for second time in 8 weeks (just to make sure). Ideas?? We know points are good--condenser (also ran distributor on test machine and checked out fine)? Ballast resistor? Bad wire somewhere between coil and resistor? Where would we generally lose that voltage? |
Bobcycleb
