  New Posts New Posts RSS Feed - fiberglass resin for floor repair
reftech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Topic: fiberglass resin for floor repair
    Posted: March-24-2012 at 7:50pm
Hi guys doing a patch on the floor of my? 82sn..can I use polyester resin?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2012 at 8:24pm
Sure, no problem for a "patch" but please, do some reading on previous stringer jobs on the site. There is a fantastic amount of info there. EPOXY!!!!
BTW,
I highly suggest it's best to keep the same problem/project in the original threat so we know the history from start to finish. If not, it gets real confusing!! If you have a problem finding your original post on your problem, go to your own profile and do a search.
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-24-2012 at 10:16pm
Thanks for replying Pete that's what I needed to know.I have some separation on the floor to hull that I'm gonna repair with epoxy resin and glass because I feel that will give me a stronger bond structurally but on my floor patch under the spotters seat I'm gonna use poly resin and then in the off season I plan on a full on stringer replacement using only epoxy.thanks again!
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2012 at 1:56pm
If it is just a one season repair it is not going to matter much what you use.
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote reftech Quote  Post ReplyReply Direct Link To This Post Posted: March-25-2012 at 2:30pm
Keeganino I agree I just wasn't sure if I would have bonding issues with the poly resin
