Fly High Pole Suggestions |
Post Reply | Page <12 |
SN206
Gimmick
GlassSeeker
Saves gas
This is the life
75 Tique
Another new "green" Obama executive order. All ski boats will now be sail powered only.
GlassSeeker
I know you're just joking but if any GOPers read this they will think it's true.
This is the life
River Monsters
Newbie Joined: August-09-2011 Location: Grand Rapids MI Status: Offline Points: 27 |
Skylon
Are the I/O extended pylons the same just with added supports? I wonder if they are missing the sleeve inside? |
We had bought a 'Big Air' pylon for our outboard runabout. It had a notched plate, that is screwed to the floor, to capture the bottom of the pylon.
It worked well, but needed a cable to each corner of the boat (4). |
emccallum
I really like my flite pipe. Maybe check around to see if you can find one.
jo-e90
Gold Member Joined: March-16-2011 Location: Midwest Status: Offline Points: 659 |
Your choice $40 or $125 With board rack Fly High $150 |
GlassSeeker
get the guy in roseville to send you a picture, it sounds like that is a barefoot international stainless steel 2 pc with stainless buckle and two cables and bow strap for 150...thats the best one IMO.
This is the life
GlassSeeker
two pc is just for ease of handling/storage
This is the life
pdhowell
Newbie Joined: September-24-2009 Location: Marylanbd Status: Offline Points: 20 |
For what it is worth, I went looking for an extension pole, but decided on the Fly High Monkey Bar. It opened up the area behind the seats, is very solid, and comes off and mounts easily. It took about an hour to drill four bolts for the mounting plates. It uses a cable to the front of the boat, either a strap around the front of the hull, or attaches to the lifting ring on the front deck.
It is not as high as a regular pole, but seems to b a good compromise between a tower and a pole. You can also mount the Fly High tower boom on the Monkey Bar if you are doing much instructing. This was a factor in my choice. Maybe useful |
Dave, Please do not attach it to the lifting ring.It's been mentioned so many times that I lost count! But, hopefully you will get more time to explore CCfan. There are tons of older threads that are very useful and full of info. Do spend more time with us! |
