450 or 600? |
Posted: September-08-2011 at 8:19am |
Steve,
The book calls for 9/16 in forward and 7/16 aft. I ended up with 5/8 forward and 1/2 aft. There is also a metering rod adjustment. I set it per the rebuild instructions. Did you ever check it? I didn't put much time on it and will go back at it come spring. I still may need to adjust the metering rods but want to pull some plugs to see how the mixture is. There's no backfiring so I feel it's still running slightly rich. |
62 wood
So Pete, how do they work? Where did you end up with the floats? btw, I just got my 4bbl intake sandblasted... |
When I made the new prop shaft, it somehow came out and inch short!! So, it was an easy solution instead of getting another chunk of stainless and starting over!! |
BuffaloBFN
I spy a donut? Tsk tsk.
Two rebuilt YH's on the 312. Steve, there really isn't anything different about rebuilding a YH compared to other carbs. I did have to open them up and adjust the float level.
Steve, I see you haven't installed your intake. Both the side draft and down draft I've seen have an exhaust crossover. I am re installing ours with the truck gaskets which have a plate with a small hole in it rather than the open port. Its supposed to keep it from getting as hot as the open port.
Well, I just finished opening up the two YH's again. I forgot to check the metering rod height which is one of the rebuild procedures. They both checked out fine but it sure would have been a problem if they were wrong.
Steve, That NOS YH you got, do you happen to know what "generation" it is? The improvements from gen 1 to gen 4 really improved the YH performance and reliability. I have the gen 4's and keep in mind, mine haven't been opened up since I got the boat (about 1981) and then it was for just a float height adjustment. The really big improvement is the design of Daytona's own needle and seat for the float/fuel level. They make their own for most of their carb kits. It's not even a needle in a seat but a flat face Viton seal (the "needle") that seals off on a convex seat. |
boat dr
Steve , so far I gotta a good 4160, fuel pump, thermostat cover...Boxed up........... Whattcha got that I need ??
peter1234
if its just about getting it running and getting the bugs out try borrowing a good working one.. we used to pass around a good working holley two barrel to each other when we had a new motor or project . it was always a known factor that we couldnt really blame the carb.. gave us time to play with valves or timing or whatever
Carbs look good painted up Pete.
Steve, Ram Air like the GTOs had, I like it! That ought to really boost the hp. |
Steve,
I feel you may need to change your screen name to something like "Mr. non original Velcro guy" !! |
Steve, We are both very lucky that we have Billy around!! So, it sounds like I can't talk you out of going non original!! |
62 wood
Actually I think its more like .. "One mans treasure is another mans even more desirable treasure!" |
boat dr
Pete we should be able to pull this off, but it seemed "SO SIMPLE" at the start.Steve and I may start swapping boxes via UPS.One mans trash is anothers treasure ????? I vote for a Pro Stock auto scoop
Ok, got it!! Hey, get a floor sweep and mount it upside down. Take the door off it and put a length of ducting on it so the top scoop area is over the windshield and wow, you'd get plenty of forced air induction. You could even do some foam gasketing around the flame arrestor to force the air directly into the carb. |
62 wood
Pete,
I was thinking more of a pc of furnace plenum, lay it down on top of the doghouse and cut the front out for forced air induction ... |
Steve,
You mentioned using an aluminum HVAC part and polishing it to mount on the top of the dog house. I just checked McMaster and they have this one available up to a 12" diameter. Cool looking!! Go for it!! And, the 12" is only $32.00. You could probably even find one at Menards cheaper!! Then, you need an angle ring and some drywall screws and the job would be done!! |
Steve,
It can be done!! There really isn't anything hard about rebuilding YH's!! The trick will be getting them back on the engine and seeing if any tweaking is needed. By now, you should be a "master tweaker" of the YH's!! Yes, there were a few extra parts left over in the kit but that's what makes a good mechanic - making it work with missing parts!! Actually, after talking with Daytona, the YH kits are universal covering all 4 generations of the carb so, some of the parts in the kits aren't used on all of the models. They sure did throw in the extra gaskets though!! I'm just trying to keep you from cutting a hole in the top of that dog house!!! There is nothing wrong with the YH carbs!!! |
boat dr
Bruce where did you get those "FACTS", my 312 is rated at 215 HP w/2 YH Carters.How much can I gain w/4 barrels vs the twins? Do you have different HP rating with a 4 barrel or you just pulling numbers out of the AIR??? If so back them up with data, not "hear say". Now back to the story....... |
62 wood
Here is a quote taken from Black Hawk Engineering . They make custom metering rods, etc for the YH. ......."""The throttle body has a 1.83" bore to fit the F flow (180 HP) turbocharger inlet bore. The Performance Trends "Engine Analyzer" simulation software predicts that the throttle body will flow 256 CFM versus 128 CFM for the original "180 HP" YH carburetor. With the boost limited to 12 PSI for longevity, Engine Analyzer predicts 193 HP net versus the 148 net HP of the stock "180 HP" system. The EFI system is able to produce better fuel economy despite generating more power. I will also manufacture smaller throttle bodies for the B-flow (150 HP) turbochargers."""... They are talking about a replacement throttle body on a turbocharged engine. The "software" predicts 256cfm vs 128cfm of the original YH carb.. ...Anyone got a hole saw big enought to cut a hole for the flame arrestor? |
Bruce, I don't feel this is true since those YH's can handle plenty of CFM's. CFM specs are hard to come by but Craig (64X55) who has a X55, did do some reasearch on them. From a good source, he found out each will do about 225 to 250 CFM. The only advantage in my mind with a 4bbl, is you have the luxury of having the secondaries kick in when needed. Take a look at the bore size of a YH sometime - they are big!! |
Steve, sounds like you got it covered. It's just bolt ons and easy to convert if you ever want to, and the padded engine box is easy to convert as well. It's not like you are going to ruin your boat. The only down side if you convert to side drafts is getting used to the loss of power from going to 2 1 barrels from a 4 barrel.
62 wood
make sure you scroll the above pic sideways!!!
you guys are just jealous! |
62 wood
Billy. I've already considered The SS intake And even mentioned it to Sieve. The thought was if he could supply me with a couple of those fancy SS intake tubes, I'd do the YH carb rebuilds for free!!!! BUT, it already may be too late.... I just pulled the second YH and sealed the 5 gal. can with duct tape. Steve nay need to wait a couple more months!! |
62 wood
if i wasnt such a intelijent man, i'd think yuo was makin fun of me and wud take ofence to them there statmunts.
btw,,,4bbl here I come!!!!!! |
boat dr
Pete, maybe a polished S/S adapter for a single YH on a 2 barrel truck intake. That way he can just swap carbs between the two engines.Even Steve can do that.....
or just put a chevy in,it's like what,8 new holes to drill?
I would put the Holley on and tear a couple of boards off the barn to raise the motor box,by the time winter comes you'll be done with the boat and then you can put the boards back.You'll have plenty of time between leaf plowing jobs to get er dun
Greg, The "first" place category comes after my rebuild test the week before Labor Day. Currently, Billy is the BIG #1 on the YH's!! At this point, what Billy has told (helped me big time) me was and all confirmed by Daytona is the only discrepancy was Billy did not know the left over part I described. Tim at Daytona knew on the spot but, he's seen more YH's!!!! Now, the big question is Will Steve actually go original, or go with a modified dog house and the down draft??? |
