  New Posts New Posts RSS Feed - gel coat questions
gel coat questions
raygunclan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote raygunclan Quote  Post ReplyReply Direct Link To This Post Topic: gel coat questions
    Posted: June-02-2005 at 7:55pm
i want to tackle the removal of the stripes (they look like decals, because of a few bubbles, but i can't imagine that a 15 inch width of decal could go on so nicely arond the boat) and in the process of checking it out, i found some cracks in the gelcoat. we plan on doing a one color job on the hull, so is there an epoxy or something similar that i could "patch" up the cracks with? i'm not really in the market to do a $1000 gel recoat on the boat, so any tips would be appreciated!
thanks!
suzanne
who needs a mortgage when you have a boat!?!?
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2005 at 1:12pm
If you are going to paint the hull, then simply grind out the cracks down to the fiberglass and then fill/smooth with Bondo to the original surface and shape of the hull.
