cheap motorbox temp reduction |
john33617
Senior Member Joined: July-07-2004 Status: Offline Points: 182 |
Posted: May-29-2005 at 3:28pm |
if your motorbox has a vent on the back , tie wrap this fan to the inside and wire so it comes on when the engine is running , sucks hot air out and makes it run better because your carb will get cooler air , ever see how your engine speeds up when lift the motorbox , walmart has them for under 10 bucks. http://www.campingworld.com/browse/skus/index.cfm?deptID=3&subOf=74,16&skunum=26213&affiliateid=590
JEFF KOSTIS
unfortunately, A fan like that is not "flashproof" for use under the engine cover. Outside would be ok.
