leaf spring |
Post Reply | Page <1 234 |
CCATW
Newbie Joined: May-31-2017 Location: Acworth GA Status: Offline Points: 22 |
Mine are snug but not tight to allow movement without too much wear on the bushings. But others likely have a greater experience basis for this question than me with just one install :).
Duane in Indy
The later, snug enough for some movement. Should be new lock nuts in the kit. Grease everything cause it does not look like the bolts have zerk fitting in them. I prefer bronze bushings but nylon is ok too. Duane
1978 Mustang (modified) |
OldSchoolBlue84
Gold Member Joined: December-02-2012 Location: Valparaiso, IN Status: Offline Points: 814 |
Kostas
1984 Ski Nautique 2001 |
Duane in Indy
Looks like you have room to double nut the bolts. Locks nuts would be my choice though. You can always "red neck" it by taking a chisel and smacking the threads to keep the nuts from coming off. McMaster carr will have the new nuts here in a day
OldSchoolBlue84
Don’t let a Pete see that All good, went back and reviewed my invoice and I actually did order the locking nuts. Well back to work on the other side Thanks for your help!
Kostas
Kostas,
Some shackles are threaded on one side so it's just like double nutting. Take a close look to see if yours's are. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21123 |
I bet the nuts are locking if they came with the shackle bolts. If they look a little oval, they’re locking.
What are you doing for the bushings? Did you get the hats and drill them out? |
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10699 |
I bet what Tim bets too . Did they thread on a lot harder than you expected? |
OldSchoolBlue84
Hey Tim, yes I did end up ordering the locking nuts with the shackle bolts. I also did purchase the hat bushings and bored them out. All fit well, just was unsure how snug there are suppose to be. The shackle bolts do have a spline to them as well. Thanks again! |
Kostas
OldSchoolBlue84
Hey Ken, they went on well, probably more resistant then a typical bolt. I did verify that I actually did purchase locking nuts. Thanks |
Kostas
