MY HOLLY IS JUNK |
kenny g ![]() Senior Member ![]() Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
![]() ![]() ![]() ![]() ![]() Posted: March-09-2005 at 4:56pm |
who has the best price on a new [not a rebuild]holly carb for my 210 interceptor.66polyhead says i should maybe use a 550.and a wedge plate.
how do i move this post down one to parts wanted ? |
kenny g
Summit racing will have the best price for new marine carbs.
thanks 79 i'll look em up on the net .
does a holly 500 or 550 sound about right 4 that engine ? 66polyhead has the old 1 and i'm not sure what it was. other than fuel leaking junk ! |
kenny g
Maybe a 450 cfm is correct. I know the listings go like 450 600 750 850 1050. If you have a catolog it is easier than using the web page. With 210 cubic in motor a 450cfm carb should be more than enough.
i didn't find a marine carb at summit.but discount inboard marine says a 4160 would work. does that sound right ? $579 ouch!
i want to be sure b-4 i order anything. |
kenny g
Summit has them for under $400
4160 is the model and not the size carb a 4160 comes in 450cfm, 600cfm, 750cfm and so on. Have Summit send you a catolog or search holley marine carburator. |
66polyhead ![]() Senior Member ![]() Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
Kenny, checked the carb. tonight. It is a list 1850-2, that no. according to Holley, is a 4160 style, 600 c.f.m.. With a primary main jet 122-66, and a secondary main jet 134-9. It is a vacuum secondary, with manual choke, no "J" tubes!
Holley marine carbs |
reidp ![]() Platinum Member ![]() ![]() Joined: December-06-2003 Location: Mooresville, NC Status: Offline Points: 1804 |
Kenny,
That Holley that you pawned off on Wallace definitely wasn't the original. Was it on the green SS? The Interceptors like mine, came with an Autolite carb. I've got one that came off mine, that I'm sure would need a rebuild that you're welcome to. Depending on the year, they used both style Autolites, the square shaped one or the elongated Holley shape. But if you're going with the new Holley, BC is correct in the 450 CFM size for a 289-302, which unfortunately I guess, because of less popularity, typically costs more than the 600. And so did you end up buying the green and light blue Mustangs? I dug up the photos just the other day that you sent me way back when. |
yes reid i bought them both.
the holley is for the green 68,i found a new [marine]600cfm for 400bucks.the 450 was well over $500 almost 600.it should work ok for now. if my new pole barn is built on time i want to come down for the NCNOA in may.sandy will be off work for two months and would be a good time for a road trip for us.i'll call you. |
kenny g
Dampilot ![]() Guest ![]() |
There's a ton of marine holleys on Ebay
nates78ski ![]() Platinum Member ![]() ![]() Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
Unless you are a fanatic on an original carb I suggest an Edelbrock marine carb with electric choke. Tuning & maintainence on an this unit is simple. On 260-289 engines 600cfm is no problem.You can find these carbs @Jegs for $300.00.
BOBM ![]() Newbie ![]() Joined: May-27-2005 Location: United States Status: Offline Points: 18 |
The chrysler 318 polyshpere motor, 210 hp
in a 66 boat originally had a carter afb-3213s. 600 cfm. Edelbrock make a good replacement, but you might try a professional carburetor rebuild shop, for less than 1/3 the money, and they should be able to tell you before hand if it is rebuildable. thats the route im taking with mine.If your motor is really a poly? BobM |
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2642 |
I had a holley 500 cfm (2 bl) on my '66 Mustang and it didn't perform better, it just used alot more gas. I switched to a holley 350 and it performs better, liked it did with the stock carb which I think is a 325.
Tim D
Jim_In_Houston ![]() Platinum Member ![]() Joined: September-06-2004 Location: United States Status: Offline Points: 1120 |
There is a new Holley 450CFM 4V on Ebay now for $469.95.
I'm pretty happy with my 450. I had it on the river this morning and my 289 ran right up to 5300RPM pretty quickly. I don't really want to go higher than that. IMHO, the 450 will do a better job of metering fuel at low (towing) speeds. I have nothing to base this on however. |
chris ![]() Guest ![]() |
you might want to check out this site. the seem pretty cheap. http://www.nationalcarburetors.com/
Chris |
