Torque specs for PCM Trans and V-drive |
Liquiddreams
Newbie Joined: September-02-2020 Location: Georgia Status: Offline Points: 34 |
Posted: September-05-2020 at 5:14pm |
Reinstalling the Damper plate, Transmission, and V-drive. Does anyone have a good source for torque specs for them? Thanks in advance
William,
If no one comes up with the specs, ID the grade of bolt by the head markings and then google standard torque specs. I've had to use that method many times.
When ya' can't find PCM numbers, there's always numbers for a 5.7 Mercruiser inboard (Chevy} Ford numbers will be different
See the link below Look under F for flywheel drive plate (MIE) AKA the damper 35 ft lbs flywheel housing to block 30 ft lbs flywheel cover AKA the dust shield 80 inch lbs Under T for transmission to housing 50 ft lbs Not perfect but it should work V drive to transmission, you're on your own so far |
Liquiddreams
You guys rock. Thanks for all of the info. I am taking pics as I go, so hopefully I can help somebody else later on. Side note, there were two 12 point hidden bolts on the bell housing. One under that plate and one in the starter hole. I have also found that if I fail at my current job I can become a contortionist....
