Stringer/ Floor Replacement Lessons Learned |
Post Reply | Page <123 |
Kjerchinger
Newbie Joined: March-31-2016 Location: Minooka, IL. Status: Offline Points: 30 |
I would like to chime in about the FOAM, NO FAOM Issue.
my understanding of the correct way to foam under a floor is after the floor is re-installed. say what ? yes, I was taught be the guy that was a former owner of the American Skier brand. he walked me through the floor replacement of my 85 AM skier. what he explained, is if you install the foam first, then cut it off at the floor level, you are opening up the closed cell foam by cutting it off. maybe you are sealing if again if you glass directly over it as was originally done at the factory. I am not an expert on that. how to install foam after the floor ? the hardest part is jacking up the front of the boat, maybe 6 to 8 feet of so. this can be done by putting blocks under the trailer axel, then raising the front of the trailer. I had access to a fork lift, prior to this, you drill 2" holes every 16" or so, between the Hull and the secondary stringers, this enables you to pour in the pre mixed foam into the holes, starting in the back of the boat until the foam comes out the hole, then moving forward to the next hole and so on. when complete, lower the boat. once the foam has set up. cut it off at the floor, and batch with cloth and resin. |
Timr71
Groupie Joined: March-28-2016 Location: Alabama Status: Offline Points: 80 |
dgray007
Groupie Joined: March-06-2014 Location: michigan Status: Offline Points: 45 |
I would agree with your overall description of how to foam the floor. Just be careful not to explode the "chamber" you intend to fill. The foam creates a large amount of force if it has no place to go...
Kjerchinger
yep, Ron Tannis, great guy !
he owned the brand until he sold it to Elan Boats |
Kjerchinger
Agreed,
my explanation was pretty abbreviated. the foam needs to be poured in slowly, making sure not to pour in to quickly, or to excessively. . |
I totally agree with the concept of foaming after the sole (floor) is in place but, that's assuming you are going to lay a ply (or composite). Many here are going back with the design that CC used with glass over the foam but I like the idea of using an actual sole. The self skinning of the foam inside a cavity provides additional sealing from moisture. I do prefer injecting rather than pouring. Less holes, less waste and a better fill over the pour into a tilted cavity. I have injected thousands of board feet of Handi Foam brand with fantastic results. |
Kjerchinger
interesting, thanks for your comments.
I used the Part A-B foam method, poured in. so with this Handi Foam, with smaller holes, is it harder to not blow out the floor by injecting too much ? my floor was plywood on my AM skier, now I am doing my sisters 83 SN, I am planning on using 1/2" foam board except under the seats, here I will use 2 layers of Cossa board. will the handi foam work ? |
dgray007
I would have used that type of foam vs the a-b pourable type but it just wasn't available when I did the stringer job. Spray foam has gotten very affordable in the last few years.
Keith, There is a learning curve determining how much foam to inject. If you do use the method, start with small amounts. If you do overfill, there is some pressure so I would not recommend the foam board. The Coosa or ply is a good idea. The kits come with extra nozzles so you can stop, let the foam kick and then go to the next cavity with another nozzle. They supply tho types of nozzles. One is for spraying and the other for injecting. The injection nozzle tip is made so you can add 1/4" ID poly tubing as an extension. I've gone up to a 3' extension without a problem. You can then get way back into a deep cavity. |
Rob-Man
Groupie Joined: August-05-2012 Location: St. Louis Status: Offline Points: 62 |
Here are some pic's of my 86 I did 8 years ago.. I am sure it is not the quality of some of the guys on this site (guys on here are expert craftsmen way above my pay grade). But she is more than solid. I use 3/4 inch plywood. you don't need that thick 1/2 is plenty. I chose not to rip out all the stringers - to scary for me (I didn't want to take the engine out). Lucky for me the main stringers where the engine was still in good shape. I took out what was bad or reinforced it. I mixed the resin with filler to thicken it to fill the gaps I had.
Kjerchinger
Looks Solid, nice job Rob
Kjerchinger
Thanks Peter-
Did I understand that the Spray Foam has become more reasonable over the years ? A quick online search I found it to be 500.00 per container... I don’t remember what I paid for the A-B pour type, but don’t recall it being anywhere near that much.. maybe by the time I get that far, sis will be umune to me ringing up her CC. How many containers of the spray would I need ? More than 1 could be a deal breaker. I will not call this project complete until foam of one sort or another is installed. |
Foam comes in different sizes sized by board feet. Calculate what you need and go shopping.
dgray007
When i was shopping the spray foam was closer to 1000 per container. the two-part is still cheaper but getting competitive with one another.
https://www.carbonfiberglass.com/Foam-Core/expanding-foam-ab-2-part-pour/2-LB-Density-Urethane-Foam-80lb-kit-40-cubic-ft-coverage.html |
A lot of interesting ideas/thoughts, especially about hanging the hull and using bondo. Anyone seen this system? They don't address rotten wood, but if they come up with a way to inject epoxy into rotten wood after the boat is dried out, stringer replacement may not be necessary. http://www.dryboat.com/ |
Bruce, The technique is fantastic for removing hogs along the keel. Daniel, Do you understand Bondo is hygroscopic? |
dgray007
So is fiberglass to an extent... Bondo use should be kept to a minimum and only used as a filler to round inside or sharp corners so the fiberglass lays down and wets out properly. If you get air mixed into the mat or mesh you pretty well just wasted your time. The Bondo, in its most basic form, is cotton fibers mixed with fiberglass resin. Bonding properties between your fiberglass resin and the bondo is really a really good mechanical bond. If you are using the epoxy type setup to repair your boat you should do some more research as to compatibility between your filler and your epoxy resins.
There aren't fillers compatible with epoxy? Maybe you should go way back when the boys started the epoxy building and repair of boats Get their book too since it has all the information on fillers plus extensive testing of the fillers. |
dgray007
There may be, but I cannot speak to them. |
dgray007
What may have been lost in this thread
Most restorers use epoxy nowadays. Epoxy is a great choice. I chose to use resin. I had a cheap source of high-quality fiberglass resin available to me. It was not off the shelf home depot garbage. There is a difference in the "filler' ratio's used to make the resin. Price bears out the quality of the resin. It is more expensive because there is less filler...I could not justify the extra cost of epoxy because of my situation. If you use high-quality industrial grade resin and the mat or mesh in the proper areas your repair will last just as long as epoxy will if not longer. If you want a 100-year repair buy a new boat. If you want a 30-year repair use you one of the repair methods above. |
jterr
Gold Member Joined: February-13-2018 Location: N. Florida Status: Offline Points: 621 |
Well I'm on my 2nd shop the 1st really messed everything up, now the 2nd guy has to find out how bad and go from there.
Gonna get a update Friday afternoon I hope. JT |
What is this "filler" you refer to in the cheap Home Depot polyester resin? BTW, I wasn't aware the HD had polyester resin but I looked on their site and sure enough here's the 3M Bondo brand. It's even stocked in my store so when I go to work tomorrow, I'll have to walk over a couple isles and take a look. Also, I have always considered 3M to make high quality products. Am I wrong? |
dgray007
3m does make a good product and I have used that exact gallon on other projects I can't get terribly technical here because I'm by no means an expert but that product is designed for small repairs. Think 1 sq foot and smaller. When you are trying to wet out a large area there are advantages to having a resin that is designed for that situation. The off the shelf 3m home depot resin is cut with calcite, or basically limestone. wet out time, work time, overall strength is fine for general small repairs. Structural repairs in large areas of a boat really call for a high-quality resin that has not been cut or filled with calcite. The biggest advantage is the speed in which the mat or mesh "wets" with the high-quality resin. With the home depot stuff, you would have to work in a 1x1 area, The industrial quality stuff will wet a 4x8 sheet of plywood with mesh with plenty of work time before the resin kicks. This gives you a chemical bond across the entire sheet creating a single panel that is chemically bonded vs multiple chemically bonded areas that are mechanically bonded together to form the same 4x8 panel. I should probably define a mechanical bond as well. A mechanical bond occurs between old cured fiberglass and the new glass and resin that you put down over the top. The chemical bond is the hardening process that happens when you mix resin and hardener. Can you use the home depot resin? sure. Will it fall apart? Probably not. Will it make your life more difficult? yep...
Hope that helps a little. Again, I'm not an expert. below is a site that explains a little better than I can. I have purchased from them and have not had any issues. https://www.carbonfiberglass.com/Resin-Systems/Polyester-Resins/6736-Premium-Polyester-Layup-Resin-Quart.html |
ScottDry
Newbie Joined: July-13-2019 Location: Michigan Status: Offline Points: 1 |
Anyone seen this system? They don't address rotten wood, but if they come up with a way to inject epoxy into rotten wood after the boat is dried out, stringer replacement may not be necessary. http://www.dryboat.com/[/QUOTE] We actually do address rot. There are a number of products, including special epoxies, that work in these situations. |
00065cccuda
Newbie Joined: August-08-2018 Location: Massachusetts Status: Offline Points: 39 |
Just got done with new stringers in my 65 coda I used the west system epoxy and slow hardener worked excellent! Used Douglas fur straight grain @ 200 bucks each! Well worth it. Used silica filler to seat the new stringers to the floor then 4" fiberglass then 6" fiberglass and up and over the stringers. Its unbelievable how much strength in the bottom of the hull with new stringers. Lots of work to get to this point all I can say is take your time this job cannot be done in one day. Good luck I'll try and post some pics soon.
lakedog55
Hi have not been on site in a while.
For sanding and messy crap a cheapo 10x20 car port is a must. I tied mine to trailer Tools to add cheapo electric hand planer. Nice for shaping and correcting or adjusting Warning old floor and hull are very close together where the front chines start. Right at the curve by front next to the gunnel. I used a circular saw and left the lip on made it easy to match up floor height. Set it just deep enough to go through fiberglass. If not using foam I would install 2 drains just in case. I messed up on this put them in a real crappy spot to get to. Material The fasco 110 is a great product for setting stringers. No problems on mine and it has been in for 6 years now. Biax mat is nice. I used it wraps better than you would think I had to special order fir and one of the mains came in with a slight bend. Trust me send it back.. I was impatient Dont need something you got to try and make straight while gluing them down pain in the butt. If you think you have any problems with wiring, cables, do it now. Also upgrade the ground wire. Look at all the pics on site. |
Lakedog55
lakedog55
One last thing. I would remove windshield if had to do another one.
Not that it is in the way. But just in case. I did not cover mine and had finger prints all over it. |
Lakedog55
elpasojon
Newbie Joined: September-12-2020 Location: st paulmn Status: Offline Points: 1 |
Laheyth
Newbie Joined: June-15-2007 Location: United States Status: Offline Points: 21 |
Getting ready to replace the floor and stringers in my 84SN, with 2480 hr on it.... its a great boat.
Question I see reference to but need details: I plan to take the hull off the trailer and build bunkers to hold it. How do you "level the hull" and know it is in the right shape? One thought I had was to mark the hull while in the water, but I can see flaws with that depending on fuel in tank etc. I see reference to hanging it from the lifting eyes Clarity would be a big help here, I dont want a hook or rocker when done. Tom
lakedog55
I had same question. Back ground in construction so level up. Not so true with boat. I used a story stick. Marked the gunnel evenly down in like 6” increments. Then used a aluminum straight edge and measured down. This gave me a reference or blueprint of where I needed to be when finished. Did this several times at different stages of demo. On the boat set up I would leave it on trailer for support and the guys here have excellent advise on where to add support to chines. I did try to get the boat level from side to side. One word of caution when cutting out old floor where front chines start the floor and hull are very close together. In other words set the saw just deep enough to get through the fiber glass on floor. I used old makita skill saw and cut right around the boat. The lip makes a nice place to tie in. Also. Couple of people have done the rear area with a drain I put drain in but not easily accessible. Also be sure to route your chases properly I have not had to replace steering cable but am dreading the day I do. Did mine about 6 or 7 years ago and seems just as solid as day one. us US Composites and this web site. Only way to go
Lakedog55
