1972 SN Promo Project |
Post Reply | Page <1 910111213> |
Layup looks good to me (lol).
What's the 50" wide biax for? I'd likely be putting a layer or 2 of cloth on the front (sub) floor section... quicker and easier (and a lot less resin) than biax or even mat. Doesn't need any impact resistance with a ply floor going over it- just sealed up and a little strength. I find that the narrower the tape, the more handy it is- I end up going through a lot of 2" and 4" and not a whole heck of a lot of 8" (at least beyond what my initial plans call for). Looks like plenty of all 3 for this build though. |
Frankenotter
Platinum Member Joined: August-26-2012 Location: Milwaukee Status: Offline Points: 1072 |
The 50" biaxial would be cut into strips. 12' for each side of the primary stringer (24" total) plus enough left over for the cap of each primary.
What type of "cloth" would you suggest for the subfloor? there seems to be 90 choices of "cloth". lol I also need to re-glass the transom components back in. would I just use normal cloth for that as well? (I.e. - exhaust ports and transom lifting ring mount) |
1999 Ski Nautique 196
Frankenotter
It's been a while since I put an update here. Summer was busy and I tired to keep a careful balance of work, skiing, and working on the promo.
I ordered the first round of supplies from US Composites so I would be ready to start glassing once the mains were shaped. Therein, lays the speed bump. I was able to finally scribe, cut, and shape the bottom of the stringer to get it within roughly 1/8" along the length of the hull. Here you can see the left side stringer is fully shaped and the right side was in progress. Both sides complete and now onto shaping the tops. |
Frankenotter
I started shaping the stringer tops but I'm taking my sweet a$$ time to get them done correctly. As previously discussed, the lip of the old floor will act as a base for the floating floor of the new design. I wanted to make sure that there was a slight angle toward the bilge to encourage water to run to the center instead of pooling on the outsides along the sidewalls. Taking this into account with the potential thicknesses of the glass being layered on the stringer took some time. Most importantly, I wanted to make sure the height and dimension of the engine mounts were being accurately cut for the use of an engine cradle.
I have it marked up and ready for one more series of cuts that will also account for the subfloor around the driver/observer seat. Ill try ti get some video of the progress when it's all fit. Since the temps have finally taken a nosedive here in Wisconsin, it looks like the CPES, peanutbutter, glassing process will have to wait until spring or early summer. In the meantime, deconstruction will be commencing on this little guy. My plan is to tear it down and get it to the machine shop sometime after the holidays. From there I can start gathering the parts needed to rebuild this summer. |
Cut your losses and buy the 28k boat
Chris,
The work is looking great Keep going when it gets warmer or get some heat in the garage. FYI, HD has some specials going on now for insulating 2x4 walls! |
storm34
Grand Poobah Joined: November-03-2008 Location: Dexter Iowa Status: Online Points: 4492 |
Style points for color coordinating the engine stand and extension cord!
Frankenotter
HW I'm going to need you to finance the $28k. I'll let you drive the boat though.
Pete the garage has big holes in the siding and he doors don't seal. I just run a torpedo heater to take the chill out of the air. No need to ventilate. Thanks for noticing Mr. Mars. You have no idea how long I had to search for an orange extension chord |
phatsat67
Tool Coordination
That explains alot. You need still more ventilation.
No he doesn't.
I understand
Frankenotter
Frankenotter
After discovering the cracked block, I continued stripping the engine to see what parts could potentially be reused. It was a bittersweet task to continue after suffering defeat in the first inning.
Video 29 |
Frankenotter
Well, I don't know why the Videos aren't showing up in the main body like they used to. Something must have changed in the format. If you know what I'm missing let me know. The links at the bottom of the post should still work.
Anyway, for those that cant watch, you can see the crack in the block above the water jacket. You can also notice in the pictures that the freeze plug directly below the damaged area is popped. I guess you can use this as a lesson to at least drain your block for the winter, even if you do nothing else. I know it's a longshot, but if anyone on the site has a 340 block they aren't using, let me know and it will go to a good home. |
jbear
thanx Larry...I knew I could depend on you for this info...just had to wait long enough. Altho I guess I could have typed in CMU to that new goggle thing on my smarter than me phone. Patti tells me that I can find out 'anything' on my own now. john |
Ahh *************** it
phatsat67
That lifter tray is awesome. Post a link of where you sourced that baby.
I will get my ear down with some of the Mopar guys on blocks and such. EDIT: Also, post a picture of the front of that water pump housing. It looks like it may be the early housing from 69 and earlier. I thought most of the small block Mopars were Sans Circ pumps until later on? I would imagine a RR impeller would be extra tough to source. I stock piled some of the early pumps for my car (accessories bolt to it that wont fit the later pump) but I would imagine swapping over to the newer pump in your case wouldn't be too hard since its easier to play around with accessories on a marine application. I think it was just my P/S pump that was the issue with swapping pumps. Alternator was ok. |
These have been on the craigslist around here a while... But they aint free
Frankenotter
Update from the land of engines.......
I am currently working under the direct tutelage of Mr. Zach who is my guide through the jungle of Mopar casting numbers and options. I have sourced a few 340 blocks in my area and now its just a matter of price and logistics. I have also been sorting through head options for the rebuild. I will dive into that subject later. For the time being, I have focused my attention on cleaning up the engine parts that I will reuse. I'm headed to a shop tomorrow that has a sand blaster and parts cleaner to try to clean the surfaces of the 30+ years of schmoo that have gathered upon them. I also started pressure testing the exhaust manifolds. Video 30 |
baitkiller
Congratulations.
Is that tub full of Miller Lite? |
baitkiller
This is kind of like re building a Sopwith Camel.
Zach knows things
63 Skier
What's the stock HP of the 340? Is the plan to stay stock, or warmer?
Colder I'll bet
Frankenotter
I think a Camel would have less corrosion and be in better shape. lol The engine plan for now is to stay with everything original, but upgrade the heads to the coveted "swirl port". This would allow me to use the original cam, intake, and stock pistons......yet offer better flow and more HP. How much.......I'm not sure. |
Frankenotter
Going to need some help here boys. This water pump is baffling. I cant find anything close to a replacement online and I'm not sure how it goes together.
Video 31 |
Duane in Indy
The sound puked on my computer so I think I know what you are getting at. Anyway, a few years ago I had a very rare aluminum water pump for a ZL1 427 Chevy engine rebuilt. They completely rebuilt it for me and only ran around $50 for the whole job. You may want to look at that option. |
1978 Mustang (modified) |
