Trans cooler |
tidrow55
Newbie Joined: July-15-2013 Location: Roanoke VA Status: Offline Points: 8 |
Posted: December-26-2014 at 7:47pm |
I just picked up a 1980 SN and top cap on the trans cooler is leaking a little around the seam. It looks to be soldered. Any reason I could not re-solder that joint?
Thanks, Dwayne |
JPASS
Not sure on the re-soldering, but I'm pretty sure a new one is less than $100.
'92 Correctcraft Ski Nautique
Orlando76
Probably could be resoldered but not worth in IMHO. They're between 89-130$ depending on the size. Attempting a repair that could cook tranny isn't worth it at the rate.
Dwayne,
Unlike the previous members who seem to feel soldering is a difficult process, I'd save the $100 and solder it!!!! How about some pictures of the new boat? |
It's just a copper tube with copper caps re-solder it, I did the one on my '85 that leaked has worked fine ever since.
Just remove all the paint, clean the copper real good with some emery cloth and solder it. Make sure you have a torch with enough heat propane won't cut it. Mapp gas or acetylene is needed. |
Since you are dealing with thin copper the same as copper sweat fittings, I question the need for Mapp and acetylene. I've used my large soldering iron (not gun). |
backfoot100
I absolutely agree that it can be resoldered however, soldering copper for those unfamiliar with the process, can be rather daunting. I make a living soldering componants under a microscope but I can't solder copper pipe for s*"t. I think it's an art form that very few can do really well.
Eddie |
backfoot100
By the way Pete, that work is outstanding!!!!!
Eddie |
I agree... If it's not busted internally and the external crack is obvious, I'd give a repair a shot. Water in the trans, I'd buy new.
tidrow55
Here are some pics of the new ride. Let me know what you think. |
Dwayne,
Nice find. Enjoy the water. BTW, no tubing! I forgot the mention that when removing or attaching the trans oil lines, always double wrench them. Since they are soldered on to the thin copper shell, the solder joint can break. |
tidrow55
Removed cap, cleaned, fluxed and re-soldered. Still need to test but I think it should be all good!
phatsat67
Nice looking rig!
gR@HaM
Cool boat!! Big fan of the retro interior
'82 Ski Tique
