Q and A |
Page <12 |
I give, ive spent 2 fricken days on a bad condensor or 2 days on a bad tach feeding back into the coil
electrical is not one of my strong suits |
PLBC ![]() Gold Member ![]() ![]() Joined: January-25-2006 Location: United States Status: Offline Points: 568 |
missing a piston?
![]() definitely taking some odd guesses here |
Nautique2001 ![]() Grand Poobah ![]() ![]() Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Tachometer causing issues with engine?
Ran a compression test on all cyl. #1 thru #7 all 175 lbs. # 8 hardest one to get to,ZERO let me repeat 0000000.what was wrong with this picture????? removed the head,no rod no rings no piston,good reason to be down on power,and that explains the Funny idle...............boat dr
Q C guy had a bad night i guess |
M3Fan ![]() Grand Poobah ![]() ![]() Joined: October-22-2005 Location: United States Status: Offline Points: 3185 |
Must be the advance. Missing the vaccuum hose if it is a vac advance, missing the weights if mechanical?
EDIT - Posted too late. I figured since the engine was tested prior to ship it wouldn't be something like a piston. |
Kurt, you were basically right. Nice job!
PLBC, you win the door prize,that one cost me in frustration and time.Send me your cell # and will call you on the next " problem child " that rolls down the drive.......
move to the front of the line Kurt F |
p/allen ![]() Gold Member ![]() ![]() Joined: March-14-2006 Location: Dixon Illinois Status: Offline Points: 942 |
How was there any oil presure without a rod holding in the oil?
Pat |
81nautique ![]() Grand Poobah ![]() ![]() Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5776 |
Wouldn't it be pushing oil out the exhaust valve.
Sounds like a tall tale there Doc, I'm not a believer yet. How the heck does that get test run and pa$$. ![]() |
P/allen was holding good oil pressure,low press.buzzer was not on at idle either. oil flow to the rod is the last place it goes.
81,that statement to me dont make sense,no piston,no suck,no piston no blow. what would push the oil out the valve.splash would be an issue but there was no oil slick in the water,nor in the y pipe while doing the repower. how did it pa$$ the test run,ask Stillwater,they did not ask for the core all they wanted was the shipping container..........go figure........boat dr |
Doc,
It wasn't a statement it was a question, guess the whole thing just sounds a little hard to believe but I'm not calling you a liar. |
Once had an asphalt paver that had a 4 cyl continental. It was running bad and couldnt figure it out we were doing tests and had the distributor cap off and it ran on 2 cylinders we also ran it on 2 cylinders with the cap on and the rotor out . Couldnt figure out why . Any suggestions?
Pat |
Page <12 |
