  New Posts New Posts RSS Feed - 351 Windsor carb to EFI done
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2012 at 12:29pm
I'm getting closer to understanding... Your explanation is very good. Can you talk to the "phasing" a little more? Im not entirely following the 20 deg you referenced- is that the total advance allowed by the centrifugal advance, or something else?
E4ODnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-15-2012 at 3:11pm
TR,
I am enjoying the questions and am very pleased to be being able to share what I have learned, but I'd like to start this reply off by reminding everyone that I am basically self taught in many aspects of this. Engine mechanics is a serious hobby of mine, and I do a lot of research, but I don't want to come across as someone who knows all the answers. There are many ways to tackle problems. I know what has been working for me from practical experience, which I'm happy to share, but I don't want to offend anyone by coming across too strong.
There. That's out of the way.
Now, rotor phasing. In a distributor you have a rotating element, the rotor, and the distributor cap, which has equally spaced terminals for the individual spark plug leads. The centre terminal on the distributor is for the output from the coil. It is in direct contact with the rotor by a carbon brush and spring steel contact. There is no direct contact from the rotor tip to the individual cylinder terminals so the spark is forced to jump across this gap. You want to keep this gap as small as possible which also means that the rotor must be "phased", meaning "aligned with", as close as possible, to the appropriate terminal. This isn't an issue with a conventional distributor with mechanical and/or vacuum advance because the advance mechanism also changes the position of the rotor relative to the distributor shaft.
With electronic spark timing you don't normally use any mechanism at all because a wider rotor tip and more space between terminals can compensate it for. If you use a small diameter cap, as I have done, then the centrifugal advance mechanism can be used to your advantage. The rotor will be perfectly phased probably over a very narrow range of your spark map. Most of the time it will be either retarded or advanced from the ideal position. It's certainly not ideal, because the mechanical advance curve is fixed, but it's usually close enough to prevent cross firing and makes no significant difference to the actual time that the spark arrives at the plug.
How to best set the phasing of your rotor is pretty much an educated guess subject to fine tuning. The best information I was able to get, if I recall, was off the SDS EFI web site, which suggested setting it at about half of your advance range. I was aiming for a static timing of 10 degrees BTDC crank, and didn’t expect to have a total advance under any condition of any more than 40 degrees. Because I wanted less error to be on the high speed loaded part of the map I decided on 20 degrees as a starting point. I rotated the crank so it was at 20 degrees BTDC for number 1 cylinder. Because it’s pretty hard to get at the distributors in my engine room I had to make an aligning jig of some sort. I had an old distributor cap which I butchered so the only thing left was the base and the number 1 terminal. This would allow me to see when the rotor tip was aligned with the terminal. With the crank at 20 degrees, and the distributor hold down clamp loose, I just rotated the distributor until the tip and terminal were aligned as close as I could see. So far I have had no reason to change this position.
Robert
1993 Bayliner 3288 "Hocus Pocus"
351 Fords, converted to tuned port programmable EFI
skfitz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2012 at 8:14pm
When I megasquirted my 75 SN's 351 a few years ago, I mounted my relay board on the intake manifold. Here's a couple pics of making the harness. Not present is the fuel pump power wire, but the rest of the harness is present. Its really not that difficult.
I thought I posted about it back then, but perhaps not. Mine is not as elaborate as the op's (mine being fuel and air only [no spark], TBI, and the ecu being velcro'd under the dash, lol), but its been in reliable service for a while, save a wonky idle air controller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2012 at 10:59pm
Skifitz,
Good for you! Nice to see someone else venturing over to the dark side.
Now the questions:
Is that a GM throttle body set up?
If so, what manifold are you using?
I've never studied the GM TB system but I think they run on lower fuel pressure than the Ford port injection does. What fuel pump do you use and is it return to tank or something else?
What version board and firmware do you use?
How about tuning software?
How about O2 sensor, how did you handle that and do you run open or closed loop?
What kind of boat is the engine in?
What's your normal cruise RPM?
Any significant differences in power, economy or just plain manners?
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2012 at 12:49am
Hi Robert,
I didn't mean to thread hijack. You are explaining the concepts exceptionally well, so I'll step back after answering your questions.
So, I drive an old Landcruiser with full-on fuel, air (MAF), spark, and timing control using MSExtra code. I had it running on Megasquirt I(!) way back in 2003. But that's another story...
My boat is a 1975 Ski with a 351w originally marinized by a company called Escort (thanks to ccfan for that information). It runs stock (Mallory) centrifugal advance distributor and an optic trigger ignition. Fuel and air are controlled by Megasquirt. Because it's fuel only, it essentially runs like a very well-tuned carb, but one that starts every time I crank it, does not get out of tune, and will run as well at Blue Mesa Reservoir in Colorado as it does at sea level.
Is that a GM throttle body set-up? Yes. They flat out work, and as you can see in the pics above, it makes for an easy harness because everything is close together.
If so, what manifold are you using? Edelbrock Performer 2181. So how does a GM throttle body fit? There's an adapter plate to make the GM TBI work on anything, even Fords. lol.
... they run on lower fuel pressure than the Ford port injection does. What fuel pump do you use and is it return to tank or something else? I would have stayed away from this had you not asked because the FP (unlike the wiring and lines) is not marine. Bosch in-line from a 1987(?) Ford Econoline. Pump is relatively high pressure, but you are correct about the TBI being a lower pressure unit. It returns all fuel over 13#psi back to the tank in the return line.
What version board and firmware do you use? MSII v3.0 Board for sure. Firmware is 2.89xx. Not really sure b/c boat's not here and I can't go plug it in and check...
How about tuning software? TunerStudioMS 2.0.6
How about O2 sensor, how did you handle that and do you run open or closed loop? No O2. Open loop.
What's your normal cruise RPM? Either just above idle or at wakeboard speed, which with whatever prop I have is about 2200-2300.
Any significant differences in power, economy or just plain manners? Like I mentioned earlier, it starts and runs reliably. I don't use the boat much, but it fires within a rotation every time I turn the key, whether it's been sitting for 3 months or we just landed a skier from the water. With the xtau accel, it delivers power smoothly and solidly. I think it does better on fuel than it did with that POS Holley carb (I hate carbs, especially that Holley), but I didn't do before and after tests so I'm not sure. Exhaust doesn't stink as much, and I rarely smell fuel when I lift the dog house.
Now carry on b/c I'm enjoying reading your stuff!
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2012 at 4:17am
Skifitz,
Thanks, but you're doing just as well yourself.
So, with no O2 to give you an indication of what your A/Fs are, how did you tune your fuel map?
I'm with you on the Holley, but to be completely fair they always started extremely well for me. It was just the warm up phase and low speed low load range that I couldn't get from being over rich. There was nothing wrong with the 2900 to 3300 range either. I had another 351, 4160 with a Jacuzzi jet on a smaller boat for a very short period of time. It was the same way, an excellent starter. I swear it would fire when the first cylinder came up on compression, or almost that good any way.
My set up starts good too, but not that good. I think it is because my code needs 3 trigger signals to confirm that the RPM calculations are valid before things completely stabilize. TFI doesn't need any input from Megasquirt at cranking revs so I didn't think that would be an issue. Perhaps it just needs a bit more fine tuning. That never really ends, at least not for me.
You are not hijacking at all. This is what I hoped my original post would accomplish. I'm so glad you chimed in because I've been scouring the net literally for years trying to find someone else who's experimented with programmable EFI on boats. Well done and keep the information coming.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2012 at 2:41pm
I installed my throttle body on a 350 in a Chevy truck and used the LC-1 wide band oxygen sensor signal to tune for 13.7-14.2 under any load at all and lean at idle. I tuned a lot. I assumed (correctly, it turns out) that the extra square inch of combustion chamber and specific engine mechanics wouldn't be terribly different when I transferred it to the 351. On the boat I set up the engine specific tables (like warm up enrichments and idle control for an engine that is fully warm at 150 degrees !!!).
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-17-2012 at 7:02pm
Fascinating! I always suspected that at least a certain amount of "generic" tuning would be possible between engines of relatively similar size and design. You've proven the theory.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2012 at 11:52am
I don't think that would work with spark, knock, etc. But for a straight air/fuel setup (even closed loop) I think it would work pretty well.
AlfaDon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2012 at 5:26pm
Are there provisions with Megasquirt for a knock sensor? From what I remember reading about the EEC-IV, it wasn't available through all the years on the stock Ford setup.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2012 at 9:22pm
AD,
Interesting about the knock sensor. During all my automotive Ford research I never came up with anything that indicated the 351W ever had a knock sensor. The 300 and the 302 did, but not the 351W or the 460.
Having said that I did come up with one mention that there is a boss about mid way down the left side of the lower intake manifold that was for a knock sensor. The fact that the PCM EFI engines have them was news to me.
I believe the later versions of MS have provision for a knock sensor input and an option for closed loop ignition retard under knock condition. The problem with non OEM knock sensors is that they can be very engine specific, and placement can be very engine specific. Also the sensor signal needs conditioning to work at the right frequency and be able to filter out other noises.
I do have a knock sensor on my engines but no active feed back. It's just there as a tuning aid, but I treat any knock report with some skepticism. I use the "KnockSenseMS" units tuned for a 4" bore. They have to be "dialed in" with a sensetivity adjustment so you have to induce an audible ping and adjust the sensitivity to suit. That's pretty hard to do with det cans in a tight engine room and a couple of 351s running at full song.
Some people are OK with after market knock sensing but I think most tuners don't rely on them. As far as I'm concerned, if I can't hear it ping, it's not a real ping. The problem with that is that my hearing is not what it used to be. I had to employ the help of my daughter to assist me setting up the ignition on my engines. She is a young mother and they have bionic ears.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 12:34pm
Actually, all PCM motors equipped with the Protec ignition system (which debuted in '91) have knock sensors as well. This includes carb and TBI boats, not just the GT40 multiport (95+).
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 1:53pm
I'm curious about this Protec ignition. Is there any information about it anywhere?
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 1:54pm
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 2:25pm
The 1993 PCM Manual in our Reference Section has some info on the Pro Tec.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 2:52pm
The PCM engines (or at least the ones I have looked at) use knock sensors screwed into the heads, with open loop control and the varying quality of gas available on the water it is a very nice thing to have. PCM might have found that they needed it to have both a well tuned and warranty safe engine:
The manual states :
When spark knock occurs, the Knock Sensor produces a pulsting electrical signal. This signal is put through and amplifier and then sent to the ECA. The ECA then immediately retards spark timing until knock is no longer sensed, or up to a maximum of 8 degrees retard. The engine will return to normal spark advance after the MAP sensor detects 3-4in. Hg. Change in engine vacuum.
The 5.8 liter PCM setup (ford marine setup) was definitely more similar to the 5.0 automotive setup than the 5.8 truck setups. Upper intake manifold, throttle body, maybe knock sensors... all 5.0 stuff.
TX Foilhead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TX Foilhead Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 3:13pm
Something you might be intrested in from the ProTec is the sensor that went in the distributor hole. Parts aren't available anymore, but it was simple and not the part of the system that had the issues. There seem to be a handful of people here who make the switch every year so getting ahold of one or two shouldn't be an issue.
Something I've wondered about that hasn't been discussed yet is how reliable is all this stuff. It's interesting from the standpoint of the person who understands and likes to tinker, but what happens for the next owner who may not feel the same way. I can see this being an issue when its time to sell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 5:17pm
How do I tell what kind of Ignition system I have on my 96 176? It has a single coil, the distributor doesn't seem to have a point set in it, unless it's under the metal plate. The distributor has a toothed wheel that I would guess is an actuator of some sort. I can't find a control box or ECU. Any suggestions?
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 6:02pm
TX,
You make a valid point and I almost didn't do the conversion because of the "re-sale" factor. In the end I went ahead with it because we intend to keep the boat for as many years as our health allows. Eventually though we will not be able to keep her in the manner to which she has become accustom and she will have to go up for sale. She will be offered for sale with the conversion in place, but nothing I have done cannot be undone. If the EFI is the only deal breaker I can remove it all and re-install the conventional set up. It would be a shame, but I expect that this will most likely be what will happen.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlfaDon Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 6:09pm
Enut
My feeling is that if somebody wants stock, then they can look elsewhere. Somebody who values what you have done will welcome the changes you have made. An old girlfriend once said "if they don't like my house, then they don't have to buy it. But I'm not going to change it to suit them"
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 6:17pm
TX,
I forgot to mention that a far as reliability is concerned it's as good or better than any normal automotive type equipment. The Ford stuff is stock Ford stuff. I've got about 8 years and over 100,000 KM on Megasquirt in my daily driver and not one MS related break down. If MS does break all parts are available cheap and anyone with basic electronic skills can repair it. The most expensive component on the board is the processor which is about 30 clams from Digikey, if I recall.
I have detailed schematics and wiring diagrams for everything involved in the project as well as the source code for the firmware in Megasquirt. I have detailed description of operation for any features that aren't typical for standard MS operations, which are covered in the Megamanual
Having said that, if the prospective buyer has any reservations at all those facts probably won't influence his decision. It won't be for everyone, that is for sure.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 6:53pm
Going back to 2003, I have built, installed, tuned, and driven 4 Megasquirt processors and have never had a component failure. I had a throttle position sensor and an Idle Air Control stepper motor fail, but those were stock sensors and would have failed regardless what computer was using them.
But that doesn't really answer your question about how reliable all this stuff is. On a forum where electronic ignition is regarded as questionable, unproven technology, I doubt it would be possible to give a satisfactory answer, but I'm saving the crappy Holley for the next owner if he or she is of a similar mind. ;)
Jllogan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jllogan Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 7:23pm
Unless someone is really plugged into to boats and their stock form I doubt you will need to remove the EFI. If it works it works. Most of my friends are shocked ski boats where primarily carburated throughout the 90's and wouldnt know the difference between multiport and TBI. So if you say oh ya the engines run good and it starts and runs someone will be willing to buy. Now I dont think you are going to be able to charge more (as with most modifications).
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 7:33pm
I think TX raises a valid point. An EFI conversion involves much more than just the brain running it all- I dont think anyone here knows enough to seriously question the Megasquirt's reliability. The other sensors and components are also part of the overall system though, and as you stated, parts can fail. When theyre assembled in a custom manner (which will usually lack the full up documentation/definition that a factory EFI set up would), you darn well better know how the system works in order to be able to troubleshoot it. Are any of the aftermarket EFI brains capable of running diagnostics (OBDI or II type stuff)? I dont know the answer to that, but they would be fairly sophisticated, if they are.
Most non-original modifications wont be met with a positive reaction by potential buyers when it comes time to re-sell. Such an EFI set up will undoubtedly fall into this category- moreso because it has a serious and direct impact on how the boat functions (not just how it looks) should it malfunction. I know I would most likely be uncomfortable buying a boat so equipped without being very familiar with how it was put together. I would think most buyers would be even less excited about such a conversion.
But, I dont think many people considering such a project are doing so with resale in mind. Like Robert said, its not like the changes are irreversible- and it may need to done to appease new potential owners.
As far as electronic ignition conversion kits go, I for one, maintain that their cost/benefit doesnt outweigh the downsides they offer in an otherwise stock engine. That doesnt mean I (or anyone else who agrees with me) has a fear of technology in general... so that comment is a little silly. An EFI conversion is likely in my future... but dont count on my installing a standalone EI kit anytime soon.
Robert, thanks for the explanation on phasing- makes perfect sense now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote E4ODnut Quote  Post ReplyReply Direct Link To This Post Posted: December-19-2012 at 10:18pm
TR,
Your's welcome, I'm glad I was able to help.
There is no question that programmable EFI is fairly specialized stuff and a lot of people are just plain afraid of it. I think that this has more to do with the fact that it is different more than it is complicated. It's really not all that bad once you understand the principals. I read somewhere once that if EFI and the carburettor were being developed at the same time the carb would probably have never reached the assembly line because it is too complicated. True or not, it makes a good story.
Modern OEM EFI systems, OBDII and later have very good methods for trouble shooting because the ECU programming is so sophisticated that it has various fall back positions and trouble codes that are set if something goes wrong. MS is a long way from that, but it does have some very good built in features.
For instance, if any sensor reports values which are over or under what would be considered to be "in range", MS assumes there is a fault with the sensor or external wiring and defaults to a relatively average value which is sort of a "limp home" mode. It doesn't set codes to tell you exactly what the problem is, but it has another couple of features which are almost as good if you are reasonably familiar with how it works.
First of all, when connected to a lap top and the tuning software, all real time engine parameters can be displayed on the screen. If the engine is running, but not running right, you can go through these parameters to find out what is amiss. Then there is data logging. This is a very powerful tool for tuning and troubleshooting. You just start a data log with a running engine and let it record all the parameters as the engine is under actual operating conditions. The size of the log is limited only by the memory available in your lap top. After the recording session you can play back the log in the comfort of your home and look for anomalies. I can't imagine tuning or troubleshooting with out it.
Robert
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2012 at 2:45am
I would go so far as to say that when the Megasquirt is plugged into the laptop, the laptop is an OBD tool. It allows you to see every input and output value any time you'd like -- in real time or in a data log. You would know, for instance, that something is wrong with the throttle position sensor when you see an erratic needle or, in my case, a static number as the value for % open when you are working the gas.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2012 at 8:09am
I agree and would be very leery about buying a boat that has been extensively converted with EFI.
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2012 at 11:11am
Most aftermarket ECU/management will have diagnostic of some kind as described above, MS is a great way to start putting your toe in the water.......less $$$ if resale is a worry to you it’s not for you....but if you like messing with stuff fill your boots as most that mess will keep the old parts and swap back to sell keeping their hoard of EFI parts for their next project or sell.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2012 at 11:50am
Totally agree Roger!
While true, you still need some specialized tools (laptop + software + appropriate harnessing) and intimate knowledge of how the system works in order to be able to troubleshoot. Which probably wouldnt work well for a subsequent owner. If they didnt want to learn the system themselves, theyre in trouble, as its unlikely they could bring it to a mechanic and plug it into a standard diagnostic tool to pull error codes. That was my point.
No doubt that by its very nature, EFI has a lot of advantages when it comes to capturing data and then manipulating it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote skfitz Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2012 at 1:44pm
Your specialized equipment comment reminded me of something: MS uses bluetooth so that I get real time display of all engine parameters on my cellphone in real time, along with GPS speed. It's pretty sweet. I'll take a screenshot next time I have it plugged in in the car.
