Cypress or doug fir? |
Hussler
Gold Member Joined: February-04-2012 Location: - Status: Offline Points: 895 |
Posted: March-22-2012 at 1:38am |
I'm finally ordering the wood for my stringers, but I found out that the lumber mill I'm using has cypress as well as doug fir.
From what I'm reading Cypress is much more rot resistant (either choice will be CPES'd) Also, are their different types of doug fir? I was reading that there are two different species. |
Keeganino
There are different species of fir but DF is a specific species. Seeing as how cypress grows in Florida and Correct Craft is in Florida and they used DF which grows out West, I would think it safe to assume they used the DF for a reason.
Don't try to reinvent the wheel... |
1973 Skier |
Hussler
Thats a very good point. The stringers are pretty bad but not bad considering they are 47 years old and look like they were half ass installed. No fiber or resin in the drainback holes!
Today I read D. FIR- PRENIUM on a piece of lumber. Does that make it without any doubt that it is what I want? It was also from douglas county, go figure. |
must_dash
Senior Member Joined: August-27-2011 Location: Lake Maggiore, Status: Offline Points: 223 |
Does Premium have less knots? i.e better grade?
1986 Martinique - sold
When we ask for advice, we are usually looking for an accomplice. |
I'd go with the Doug fir. The Cypress is on the oily side which gives it the rot resistance but also makes it harder for epoxy to bond to it. However, with a CPES treatment, it's not that big of an issue.
Even though lumber grade titles will vary among lumber associations and regions, "premium" is a new one for me. The typical grading system with use #1common, 2,3,4 or higher grades will be have a letter grade (b,c,d). Don't forget to ask them to get the moisture meter out and check the lumber. I suggest 8% or lower. |
Hussler
So a 3 or 4 is the highest grade (or a c,d) ? Is there a moisture content that is too low? (IE might start cracking?) If its 8%, I can use it immediately, epoxying and what not? Also, did CC use polyester resin or epoxy resin? |
The higher the nunber and the higher the letter the poorer the grade. The lettering system is typical to finish (select) lumber and the numbering is typical of common lumber.
The 8% is a good starting point. Yes, you can start with the CPES at about 8% or lower. There isn't a too low percentage. |
Hussler
Well I've called about 12 different lumber places in about 100 sq miles. I'm just going to have to get the fir from home depot, bummer. Theres a local place that sells it but they store their lumber outside.
juniorwoody
Gold Member Joined: August-09-2011 Location: Oak Hill, Fl Status: Offline Points: 937 |
You need to check cabinet shops or woodworking shops. If they don't have it perhaps they can tell you where to get it.
65 'cuda
"premium" = big box marketing
YES!!! The "home centers" will have C**P and probably Hem fir and not Doug!! |
Hussler
It is in fact Doug fir, stamped with a WWPA rating. I bought all the pieces I needed, Once coated in CPES it won't matter.
Took a while to find really nice pieces but it was worth it. |
I'm surprised and glad you found it. |
