Wont turn over |
TheChad1976 ![]() Groupie ![]() ![]() Joined: October-12-2009 Location: Jacksonville FL Status: Offline Points: 44 |
![]() ![]() ![]() ![]() ![]() Posted: March-19-2012 at 11:46am |
Brand New battery, but the starter wont turn over, not even a click at the starter. Ignition comes on, blower runs fine, and when you turn the key you can see the volts drop a little so that seems to be working. Where should I begin? Would the external starter solenoid cause this? Any help or ideas would be much appreciated.
Check to see if you have the volts going from the ignition switch to the start relay. The NSS is in the circuit too so see if it's Ok.
Totally forgot to add, its an 87 Ski with the 351.
I have had issues with the NSS before but usually move the throttle a little and it fixes itself. No such luck this time.
Time to break out the multimeter and figure out where youre not getting voltage!
QUEBEC ![]() Senior Member ![]() ![]() Joined: August-30-2009 Location: NEW JERSEY Status: Offline Points: 216 |
Neutral safey switch on trans. Check for battery voltage going in to the switch and out with key on and in neutral position. if no voltage comming out jump the switch and and see if it will crank over. Also check the braker on the back of the engine.
NEVER EVER GIVE UP ON YOUR SELF YOUR FAMILY YOUR FRIENDS AND GOD THERE ALWAYS A NEW DAY
Fixed this problem. It was the starter solenoid. Turns over fine, but not it won't fire.
Voltage to the coil?
Ok looks like I got it fixed. Its atleast running now. New Starter solenoid, new plugs, and some starter fluid and she runs...
BAD!!! The stuff is basically ether which is a very strong solvent. It will wash the oil film off the cylinder walls. You have just removed several hundred hours of your engine life. You should NEVER have to use the stuff. Why did you?????? |
