prop shaft removal |
Post Reply | Page <12 |
Author | |||
Ben, You haven't worked hard to keep water out of a bilge unless you've owned a wood boat that needs a new bottom! Have you owned one? |
benrankin33
Groupie Joined: March-20-2010 Location: tallahassee Status: Offline Points: 43 |
I have never owned a wood boat, but I can only imagine, thanks again for the info.
LaurelLakeSkier
Senior Member Joined: February-12-2007 Location: Wisconsin Status: Offline Points: 485 |
It was nice that you didn't mention Pete by name..... |
Ok, I seem to remember that you were always the one who needed his beauty rest and never wanted to be out very late at GL!! Those barefoot runs sure and hard on the older generation! |
be sure to call Elberts direct, if not the shafts are pricey...do a search, i guess i can do that now unless someone distributes ARE shafts
benrankin33
Cecil sent me to Discount Inboard Marine, price is 315.00+shipping, do you know of a better price somewhere?
it sounds like Cecil is using the code of the road, still cheaper than a single taper.
DrCC
I should have waited, I gave 336.00 4years ago.
I used to work on boats that were equipped with the dripless seal. IMO they were a lot more hassle. I have always run my stuff box a little tighter, maybe 6 drips a day. this way any drips will evaporate. AT |
benrankin33
It sounds like I should stick with stuffing box, sure is alot cheaper!
malibud
Gold Member Joined: July-08-2009 Location: north carolina Status: Offline Points: 613 |
Skidim is the cheapest for the shaft w/ the 10% discount kind covers shipping
benrankin33
Dan, Is Discount Inboard Marine the same as Skidim?
benrankin33
Never mind answered my own ques.!
I am happy with the gore-tex packing. I only get about a pop can's (soda for you easterners) worth of water in a several hour wakeboard session. More water than that comes from the boarders!
DrCC
hahaha! Chris, Pop turns into soda south of Lineville, IA also.
AT |
emccallum
I put in the PSS in my 82 several years ago. Clean dry bilge, . But, you are right, it is pricey.
benrankin33
Has anyone had any experiance with tho OJ dripless seal, it's 50 bucks cheaper than PSS?
Morfoot
It's a Coke can's worth down heahh in da south. |
Ben, You really must have a phobia about water in the bilge! Do you know how to swim? |
benrankin33
Pete, I am a very good swimmer, but you are partially right, water in the bilge does bother me.lol!
jbear
You 2 guys are killin' me...wanna compare birthdates? john |
wetskier2000
Senior Member Joined: September-07-2005 Location: New Hampshire Status: Offline Points: 367 |
if I pull the prop first, can the prop shaft slide by the rudder or do I need to pull the rudder also?
Current: 1997 Nautique
Previous: 1987 Nautique 1964 American Skier |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6114 |
97? Should be offset enough to get the shaft past the rudder. I dont think that was the case in older boats.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10780 |
Is this dealing with your thread in the link below asking about replacing your cutlass bearing? I'd lay under the boat and see if you have any rudder offset as a start.
wetskier2000
thanks guys... Yup, just getting around to changing the cutlass bearing now...
