Test your CC/SN knowledge |
Post Reply | Page 123 4> |
Author | ||
Hollywood
Posted: April-18-2016 at 12:42pm |
The math just doesn't work out. A 700lb power plant wound need to be over 7" off center for the boat to be balanced out by a 150lb person on the opposite gunnel (I used 3'). Just not possible. |
quinner
If I am understanding what you are saying, the motor is off the centerline of the hull thus creating a situation where it is heavier on one side than the other. What is the total weight of a python, 700lbs or so?? How far off center would it need to be to equate to 20% more weight on one side over the other, enough to create a list??
Adding some lead to the opposite side should easily fix this issue, further forward could possibly even have a positive effect on the slalom wake. |
T_bone19
Groupie Joined: June-20-2015 Location: canada Status: Offline Points: 53 |
All jokes aside. Thanks for all the replies, this really helps.
I laughed so hard on the joke about a photographer. So true ! Thanks again, Tyler |
DrCC
So, If you have perfect alignment at the couplings, and your shaft sits perfectly centered in the front of the log and your engine has to be slid all the way to one side in the front mounts.
This means your strut is still not adjusted exactly perfect. And I too don't buy into the idea of an engine, no matter small or big block, sitting all the way to one side causing any kind of visually noticeable list. |
Tyler, It doesn't seem that you are comprehending the concept. I mentioned it and Kevin has again, if everything is centered, the engine can't be off centered unless you have some really bad alignment problems. Did this "tech" even check the overall alignment? Yes, get the tape out and get some measurements yourself and DO NOT worry about the port to starboard placement of the stringers in the hull. BTW, why did you edit removing your pictures? |
Chevy350
Gold Member Joined: June-24-2013 Location: Illinois Status: Offline Points: 721 |
Wow, I bet you could pull a lot of tubes with that amount of HP. #CoolestGuyOnTheLake |
1972 Mustang
Hollywood
Easy Gary he's not a photographer.
Or pictures
Hollywood
I'm still not buying this is entirely engine related and there's no wet foam there.
If everything is centered your alignment is WAY off. So much BS here. Why don't you take some measurements? It doesn't take a mechanic to use a tape measure. |
T_bone19
Hey guys Nautique told them everything to look for. Everything is centered except the engine(remember the engine is massive, my clam shell takes up half the boat.
I like al the ideas |
Kevin, The "strake" can't be off center since the hull comes out of a mold. I feel you meant the strut? So far, I see no mention about the position of the strut, log and prop shaft which if off center sure would position the engine off center. The position of the strut would be the very FIRST thing I would check if engine position was questioned. Unless it just wasn't mentioned, I sure would question the "tech" who checked the alignment. |
T_bone19
Could be interesting point, but I am not a mechanic or an engineer.
I will leave that for them to find the root cause. Kevin - Not sure what you mean by something wrong with me. So glad I shared this information with you all. Great forum! Kevin when you get a boat that has more than 400hp, come talk to me. "LOL" # suckmywake |
KRoundy
These are hand-made machines. No two are exactly alike. Odd that your boat ended up so off-center. I'm curious - this has to mean that the driveshaft, strake and prop are off-center too, right?
Hollywood
There IS side to side adjustment in the motormounts, that's needed for alignment.
It doesn't matter where your stringers are (even if off center), if the engine is aligned you're good to go. There could be a chance the strut and log are way off the centerline causing the list but nobody seems to be checking for that. Other than you saying the list was more pronounced at rest we still haven't seen any 34-36mph list evidence. So far there is nothing wrong with this boat, just the current owner. "lol" |
Many like Joel don't let a slight list bother them! |
What happened to Tyler's pictures? Have they been removed? Can anyone see them?
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4249 |
Sorry then, my mistake!
I did look back at Joel's post (M3Fan 17th post down) and he said there is some side to side adjustment? I didn't realize that. I'm still not clear how it could align if that far off center. |
T_bone19
I think you have misunderstood my post and my tone. Perhaps I could have put a lol at the end of it.
Just paying the info forward. |
63 Skier
Tyler, no need to get defensive. As you saw from the responses, people here genuinely wanted to help you get to the bottom of your problem with the boat. And I don't mean to offend you with my question, just seems to me a tough argument to make that the manufacturer still has to do something about this.
As for a fix, if the stringers are not symmetric and placed incorrectly which puts the engine off center, there isn't a side to side adjustment in the mounts to compensate for that. What baffles me a bit with that conclusion is if the strut/stuffing box are properly on center, how did they get a shaft to align with a motor an inch off center? |
T_bone19
LoL...Tell me something I don't already know, I think your right.
At the very least I was able to find some information and details about a rare boat that I didn't know and passing it along with all of you. Thanks for all the interest in this post Tyler |
17 posts in Joel nailed it Wish you luck but I don't think you have a leg to stand on. Boats 17 years old,your not the original owner and the boat has not been recalled. A recall is for safety issues which this is not. I would think this is more of a manufacturing defect that the original owner either didn't realize or care.
63 Skier
So if nothing needs to be repaired, what do you want them to do for you?
T_bone19
63 skier - Just a point of clarification
There is nothing wrong with the boat that needs repairing, so your point is a little misguided The issue is the boat was not manufactured properly and they deemed it appropriate. The boat is a defect and should have been recalled. No different than a car recall, your car can be 20 years old and it gets recalled. "Rest assured we stand behind our products...Live without compromise" Greg Maloon, CEO Nautique Tyler |
63 Skier
Tyler, I wish you luck but it's a 17 year old boat that you bought just last year. Seems like a stretch to expect the manufacturer to repair it for you.
Glad to hear that Greg was responsive. |
T_bone19
UPDATE - Final Verdict
Had the dealer drill a hole at the back and check the foam . Good News: Foam is not waterlogged no waterlogged foam in the boat What's causing the list Engine is about 1" or less off Centre to starboard side, the big block would have enough weight for that deviance to give the list. Check with Manufacturer - Nautique "By design, deal with it ".... Nautique expressed that this is a normal and common place in those years of the SN. As long as the boat is level underway it was deemed acceptable. Had dealer check/confirm that the propshaft came out of the port straight and it does. There is no side to side adjustments in mounts for this...it is structurally stringer placement on assembly, Cost me $$$ for Nautique to say by design deal with it. File a formal a complaint with Nautique and I am currently in discussion with Greg Maloon. He did re-confirm their position and performance criteria of SN at the time of manufacture was for the boat to be level at skiing speeds( 34-36mph) He has forwarded my complaint to C/S, not expecting much. However, i must say i was impressed he responded to my email in fairly short order. Like I said to him this is where the prop hits the water. Stay Tuned, Cheerio Tyler |
LeftFieldEngineering
Senior Member Joined: December-20-2010 Location: Monson, MA Status: Offline Points: 384 |
Any more news on this?
Mojo
Grand Poobah Joined: December-06-2006 Location: United States Status: Offline Points: 3104 |
+1 |
05' SV211 TE
Hollywood
You would know ^
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
Big ladies love boat rides.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21141 |
Still waiting on interior pictures. Under bow, behind panels, etc.
Spent some time on scoots python this weekend and it sat level at the dock. Had a boom under the observer seat and 1/2+ tank of gas but otherwise unloaded. |
