oj xpc dripless |
Author | ||
Jllogan ![]() Platinum Member ![]() ![]() Joined: May-18-2011 Location: canton, OH Status: Offline Points: 1728 |
![]() ![]() ![]() ![]() ![]() Posted: April-24-2012 at 10:41pm |
thanks gentlemen the successfully installed!
if you wouldnt have injured your elbow at your croquet tournament, I wouldnt have borrowed it, you would have done it for me! It was actually alot of work trust me you didnt want to do it.
dont forget, I am a bearing puller thief too. They are both on ebay right now if you want them back. maybe if you would ever invite me over I would bring it back. |
watrski ![]() Senior Member ![]() Joined: December-01-2010 Location: Chippewa Lake Status: Offline Points: 393 |
Reamer thief.
Sorry tim I just dont trust you. |
No....won't be a problem or I would not suggest it ;) |
8122pbrainard ![]() Grand Poobah ![]() ![]() Joined: September-14-2006 Location: Three Lakes Wi. Status: Offline Points: 41040 |
The circulating pump does just as it's name suggests - circulates. It's the RWP that provides the water/pressure for the cooling. The water going to a dripless seal is really not for cooling. It's more for lubrication. The dripless is a modified commercially available mechanical carbon and ceramic faced seal. They need water between these faces. They also need to stay realatively clean and the reason you don't want to suck water backwards out of the lake. Any junk from the lake and it may get caught between these sealing surfaces. |
ahh, there is a little drain plug in the bottom of that correct? I think I have a little elbow fitting that would fit in there, maybe. Still thats before the circulating pump, would that be an issue? The claim they dont actually need cooling.
trying to get motivated to tie up all the loose ends before I send the boat up to FFM. |
Pull it off of the bottom of the "J". Thats how mine is/was plumbed.
I wasnt sure of the flow of the water from the seal. I thought maybe it took water from outside the boat and flowed from the seal to the water lines in the boat. So you are saying that wouldnt work/it doesnt work that way.
Its just with the alternator on the port side and the PP on the starboard things are a little crowded. Port is the longer run of hose so I guess Ill try and get it in there. |
Justin, Think about this a second. If you "T'd" on the suction side of the RWP, it would suck water and not deliver water to the seal, correct? |
can the water line for this seal be "T"ed in on the water line between the strainer and oil cooler? Or does it need to be after the circulation pump. Thing are a little crowded up there and it would be alot easier to plumb it in before the RWP.
