  New Posts New Posts RSS Feed - GT-40 Spark Plug recommendations?
MdFooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MdFooter Quote  Post ReplyReply Direct Link To This Post Topic: GT-40 Spark Plug recommendations?
    Posted: June-07-2016 at 3:19pm
Gentlemen,
Question of the day,
2001 GT-40 in a Sport Nautique, I see that the Owner's manual recommends AWSF 22 or equivalent, but I'm curious about a platinum plug. Autolite web page shows Iridium XP25 as compatible.
Any experiences good, bad or otherwise?
Thanks for any and all help!
KP
KP
1st85 Nautique
2nd
Status: Online
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2016 at 3:33pm
Autolite 764 is the plug for the GT-40 engine. You don't need platinum, iridium, etc. The Autolite 764 is a copper core plug in the proper heat range for your 351 engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2016 at 7:51pm
Some places will tell you that 764's are being discontinued. That probably means there's only a 20 year supply left floating around out there.
Autolite 104 is the replacement for the 764 and is functionally the same plug, only difference is that the 104 has full threads on the body and the 764's are only threaded halfway.
If you look inside the plug hole on a GT-40 or 40P, it will be obvious why either will work.
Edit, you'll also see why an Autolite 25 physically won't work in a GT-40 or 40P head.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MdFooter Quote  Post ReplyReply Direct Link To This Post Posted: June-08-2016 at 12:52am
Thanks for the excellent info guys. Autolite 764s it is. Even Amazon has them.
KP
1st85 Nautique
2nd
