Beeps during warm start up |
gdurham
Groupie Joined: November-19-2007 Location: United States Status: Offline Points: 49 |
Posted: December-20-2007 at 6:50pm |
My boat (2005 206 limited) beeps with a low voltage warning during start up after a short time it goes away or if I increase the RPM's the warning goes away. Dealer said this is normal. What do you guys think?
Gregg Durham, 2005 Yellow 206 SN limited on Manitou in Rochester, IN
87BFN owner
Check the belt tension, check wire connections to make sure they are tight. Make sure none of the connections have corrision on them. As it is a new boat, it's most likely a loose belt or loose connection.
