Tower Mirror Vibration |
Mark P
Groupie Joined: November-24-2006 Location: United States Status: Offline Points: 57 |
Posted: November-24-2006 at 12:50pm |
Does anyone have any suggestions on how to dampen the vibration of the mirror mounted on a '05 216 Sport Nautique's tower (standard factory supplied arm)? At certain speeds, the vibration makes the view blur.
dans
Senior Member Joined: March-23-2006 Location: United States Status: Offline Points: 187 |
Your prop should be checked.
Mark P
The prop is not dinged but could be the issue, as well as anything out of balance. The frequency happens to be at wake boarding speed only @19.5 MPH. It could also be just one of the natural frequency speedi issues of the drive train that occur. Manufacturing equipment that I have worked on are sometimes prevented from running at speeds where vibrations occur - that's why variable frequency drives have "skip freqencies". If dampening out this vibration cannot be done, I will taking it in to have it looked at.
Mark P
Also, I may have to consider a windshield mounted mirror like my previous Nautique had (that was a black CIPA). Does anyone make one that has a silver or brushed aluminum look that mounts on / above the windshield? I have searched the web and have not found one yet.
eric lavine
matchbook....seriously you could of scraped some sand and would never know it I would go after the prop first, the boat should be smooth at all rpm ranges, remember the prop spins engine speed unless its a 1.23 and that is very fast.
05 210
Platinum Member Joined: February-17-2006 Location: Southern Maine Status: Offline Points: 1481 |
Never had a problem with mine getting blurry.Different boat,but the tower is basically the same.I would take the above advise and get 'er checked.Moving the mirror is just a band-aid.
Mike |
