does thermostat open? |
Post Reply | Page <12 |
M3Fan
Just filled up my engine with non-toxic green AF (yes, it exists for cars in non-toxic formula). I filled it using the inlet hose for the RW pump- never started the engine, just poured it down the hose with a funnel. Dead cold, the engine took in over 3 gallons with no hesitation. Could have been more. Could there be an air pocket? Possibly. If so, it's a pretty small pocket- I was amazed at how much the engine took in.
Hollywood
Moderator Group Joined: February-04-2004 Location: Twin Lakes, WI Status: Offline Points: 13511 |
I want to say we used exactly 3 gallons as well in the '88 351.
HOT FOOT
Newbie Joined: November-07-2006 Location: United States Status: Offline Points: 4 |
I've always drained the block and manifolds and then sucked in A/F using the RWP hose. As long as the block is empty it will fill with A/F. I like this way better because I know the RWP, trans cooler etc are filled with A/F. It has gotten as cold as minus 30 degrees where my boat is stored and never had a problem. Also make sure to mix A/F and water as straight A/F will freeze.
'99 nautique super sport
25XS
Newbie Joined: October-31-2005 Location: United States Status: Offline Points: 16 |
They did... www.xtremeheaters.com 5 minutes to install in a skiboat: TOPS! Kicks on at 40degrees F and off at 45degrees F and keeps your engine safe as long as you have electricity plugged in to it. I sell the heck out of them. Tom |
"Stock Stuff" by day... Racing Mercury outboards on the weekends.
1991 Nautique Excel "thousands" of hours... |
