Throttle cable air leak |
Andrewkelly1983
Newbie Joined: May-24-2020 Location: Wisconsin Status: Offline Points: 30 |
Posted: August-19-2023 at 11:12am |
Morning!
Looking for some Expert advice! 1990 ski nautique with a carb 351. I have what I think is a air leak in the throttle cable that is causing a rough idle, stalling and inconsistent acceleration. I can hear air hissing near where the metal section is close to the carb linkage. Any thoughts on how to address that his? I would like to just try and get the boat through the next few weekends then do a more extensive tune up this fall. Thanks! |
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2842 |
The Holley carbs are known to develop wear on the throttle shaft that can lead to an air leak. This is a YouTube video showing a repair to a Holley 4160 throttle shaft:
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10650 |
How about a leak at the base gasket, it's a lot more likely than a leak on the throttle shaft?
