'81-'82 PCM wiring question |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 888 |
Posted: July-27-2019 at 10:03pm |
Two boats (SN's) with their original PCM carbureted 351. Regarding wiring, and specifically the 8-pin gang connector near the electrical panel on the engine...any difference from '81 to '82?
Thx. |
1994 Ski Nautique "Riot"
You mean engine harness to the boats harness? If so then no difference they are wired to a standard, my 69 Mustang and 77 Shamrock use the same harness
MourningWood
Exactly what I was after...thanks Gary.
I was getting a big spark when connecting the battery.....'82 drivetrain into an '81. Turns out the blower switch was on. Onward....thanks again. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10696 |
Both of those years should have had the Prestolite alternator with an external regulator and probably an ammeter on the dash.
If that's the case the engine harness is the same. Later years with Motorola/Mando alternators have a different harness due to alternator wiring. Maybe Gary is saying the plugs will plug into the boat harness, which they will, but the alternator may not charge. You must have the same alternator/voltage regulator setup on both boats Gary? |
MourningWood
Thanks..in my case both Prestolite, so fingers crossed plug 'n play
It should be this wiring diagram for both
MourningWood
Awesome, thx. .Will print/save for future reference.
