Fuel Pump |
Duane in Indy
Posted: September-21-2016 at 2:27pm |
Am going to repair or replace this fuel pump Not enough pressure to suit me.
1978 Commander Ford 302V8 Question 1 is: What do I order and where from??? Would rather rebuild if the parts are available. Question 2 is: Going to order double taper coupling from NP and need to know what our discount code is. Plan is to turn the taper on my existing shaft and use it . |
1978 Mustang (modified) |
quinner
PND gets you 10% off
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10647 |
Hi Duane
That's an AC dual diaphragm marine pump. I don't think you can find a rebuild kit for them anywhere. You can find replacements for that at ebasicpower,com (Sierra 18-7267) or you can replace it with the Carter style with the overflow tube that goes up to the flame arrestor/carburetor. KenO |
