my Timmy T |
Post Reply | Page <12 |
gt40KS
YUK, Pete ... Wow. I'd get bottled water.
Having said that, the strainers we use don't filter down to the micron level anyway - a .07" particle will pass right through. I'd say all that Yuk is headed through the engine one way or another. But yes, I am doing all new plumbing, flushing T and a new strainer after I get the engine in and I will be installing the T before the strainer... just because |
JCCI
1995 Ski Nautique GT40 |
gun-driver
That's why I put this on my shower.
And I go with the simple bucket |
nhhandyman
Newbie Joined: August-24-2017 Location: Maine/NH Status: Offline Points: 28 |
Thanks for all the replies - I'll post a pic next time I get to the boat.
I also went for the 1"x3/4"x1" Tee - not the 1x1/2x1 listed above. |
WinterTurtle
Groupie Joined: July-18-2017 Location: Summerfield, NC Status: Offline Points: 79 |
Does the tee need to be installed between the rwp and the trans heat exchanger - or between the inlet and the heat exchanger? I don't have a strainer (yet)...
1979 Southwind 18 351w
Not Running - All Potential! |
nhhandyman
Here is mine - installed yesterday - will be trying it out at some point this week.
And yes, I will be getting a plug just in case that ball valve chooses to open up... |
No plug necessary.
You’re going to have a hard time priming the pump with that location. |
nhhandyman
priming the pump....
why... because the water will be heading out the inlet before getting sucked in? |
Correct, only an issue if the pump isn’t already primed. |
