Took the M17 out for its first shake down |
KooK
Senior Member Joined: February-10-2014 Location: Iowa Status: Offline Points: 143 |
Posted: July-30-2016 at 8:46pm |
1979 Mustang 17 w/ 302 4V
Did really well for having only 10 hours logged in the last 5 years (so the previous owner tells me). Somebody put in a rubber expanding freeze plug (one you can pop in and out easily to drain the block) and under a WOT run it popped out. Ended up catching it quickly, engine got a little hot but nothing crazy. I logged a top speed of about 45mph on the GPS with a very, very old 3 blade prop. Engine sounds very healthy it seems. Love how the thing sounds. Things I need to replace: Valve cover gaskets PCV Grommets Oil cap gasket Freeze plug Exhaust manifold hoses |
