New Carb, still hard starting and now hesitating. |
1StopJeff
Groupie Joined: May-10-2012 Location: Granite Bay, CA Status: Offline Points: 43 |
Posted: April-24-2013 at 8:00pm |
Need some help. I took the stock carb apart and it didn't look too good so I just bought a new marine 4160 part# 0-80364 from Summit for my PCM 5.8. I installed it and it is still somewhat hard to start and now I have a hesitation coming out of the hole. Can someone point me to a tuning guide for this carb or give some advice? I used to be able to tune the heck out of a Quadrajet but that was 25 years ago and haven't done much with Holleys.
1991 Nautique Excel
cphase
Gold Member Joined: May-11-2010 Location: Newnan, GA Status: Offline Points: 795 |
Have you checked the timing? If so what was it?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21123 |
Have you checked your timing?
cphase
Great minds!!
1StopJeff
Yes, timing is at 10 degrees per spec.
1991 Nautique Excel
cphase
80364 is 450 cfm for a 5.0/302, you nee a 600 cfm 80319 for a 5.8/351.
I doubt though that has any bearing on you hard starts. |
wwchevy
Senior Member Joined: August-22-2011 Location: Michigan Status: Offline Points: 369 |
Was there a problem other than the hard starting that prompted you to remove the carb and take it apart? Is the carb the only component you changed? Did you confirm you are getting a good shot of fuel when you push the throttle wide open?
wwchevy
1989 Barefoot Nautique |
1StopJeff
The boat had been sitting for a while before I purchased it. It was very hard starting and I was going to rebuild the carb but when I took it about it didnt look so good so I decided to replace it. I did confirm that it is getting a good shot of fuel down the primaries.
1991 Nautique Excel
1StopJeff
That is interesting that it is the wrong CFM for the 351. Besides the hesitation is sure runs out nice.
1991 Nautique Excel
JasonR
Newbie Joined: May-31-2007 Location: United States Status: Offline Points: 37 |
Points, plugs, cap and rotor. Check the ballast resister.
'86 2001 800hrs
Bri892001
Are you getting that shot right away? Take up any slack in the accelerator pump adjustment screw. If the throttles are opening without that shot coming immediately, you can get a hesitation. |
